Home built cab
/ Home built cab #1
DEON
NS Canada
Kioti CK25 HST w/home built cab
I just started looking into this forum a few days ago. I love it. It's full of interesting stuff and interesting people. Though some of you may like to see my home built cab. I had a Sims cab that I did not like. Too much steel and not enough glass. I saved the door latches, the roof panel and the heater. All the rest is new. I made patterns and ordered tempered glass with holes for hinges, wipers etc. Had fun designing and building and now have fun using it.
/ Home built cab #2
Welcome to TBN!
Very nice job!
You done such a great job that it looks like a factory cab.
What kind of metal did you use for the frame ? ... It doesn't look like tube.
Thanks for sharing.
/ Home built cab #3
What a nice looking cab! Do you have build pictures? I would love to do something like this... Any details and more pictures would be greatly appreciated.
/ Home built cab
C'mon DEON, who do you think you're fooling ?? ;);)
How about a before and after photo.
Can you tell me what brand this cab is if it's not home built?
Built of 2 x 2 x 1/8 square tubing with 1 x 1/8 flat bar welded to it for door an d window stops. Yes I really did built it, with a mig-welder, chop saw and aerosol spray cans.
/ Home built cab #6
Nice Build. Do you have any unfinished / in construction pics? Looks like you lengthened the cab a bit
/ Home built cab #7
Deon:
Excellent work! I can see why you wanted more glass. If you have more in progress pictures, we would love to see them.
Be sure to check out 4shorts work as he really does an excellent job of tricking out his tractor and other equipment.
/ Home built cab #8
very nice , I built mine using original rops lowered by removing the hinge and raking the roof down and attached to similar front rollbar welded to fel. installed front and rear windows. have not figured out doors because of compound curves. Lookes like you widened and squared off yours. waiting to see more detailed pics. I do notice your "edge" as a glass mansfacture. have not noticed many cabs here, and yours is very nice. Terry
/ Home built cab #9
impressive!:cool:
/ Home built cab #10
Nice Job, I would love to see some "Under Construction" Pics of this build.
/ Home built cab #12
wow, impressive job.
More pics of this would be good! Did you use the original rops? If so, how does the cab mount to it?
/ Home built cab #13
Nice cab. I think Sims should $buy$ that design from you.
/ Home built cab #15
DEON
Man that is a very professional looking job. Way to go and by the way welcome to TBN you will fit in hear very well.
/ Home built cab #16
Deon: Another ex South African ?
Great job, I may need to do the same for my Bobcat. I worry about the noise level inside an enclosed cab, but maybe I worry too much.
I'm in the Napoleon, Michigan area. Lived in Newcastle, Bethlehem, Saldanah, PE, Mossel Bay and a few places in between, before relocating to St Martin in Germany and then to this place.
Looking to skip the unemployment state as soon as I can get out from under my current home (a familiar tune to many right now) and then looking to move to Colorado.
Regards
Keith
/ Home built cab #20
Glass or plexy?
were did you source it?
Seems the most difficult part of a home built cab is the "glass" portion
500BBL WHEELED...
2015 C.GALLEGOS PNEUMATIC TRAILER (A60736)
2015 C.GALLEGOS...
Utility Cart (A59231)
2018 FREIGHTLINER M2 4X2 26FT NON CDL BOX TRUCK (A59906)
2018 FREIGHTLINER...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
