cyl mounting angles
/ cyl mounting angles #1
northernguy
Member
I want to make my rear blade tilt and angle hydraulicly.What would be the proper mounting angle of the cylinders to put the least amount of force on them when draging the blade.I'm thinking of using either a 6" or 8" stroke cly.
Should the moving mount be closer or farther from the blades pivot point.
/ cyl mounting angles #2
northernguy, the farther you mount the cylinder end from the blade pivot the less force on the cylinder, but the longer the stroke on the cylinder has to be. You did not say how big of a blade you are working with, I used a 2" dia X 8" stroke on my 60" blade it is mounted about 8" from the blade pivot, I have no problems with the cylinder. Your distance from the blade pivot will be determined by the cylinder stroke and how far you want your blade to pivot.
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2021 BROWN & HUBERT 10' SPOOL TRAILER (A63276)
2021 BROWN &...
JOHN DEERE 467 ROUND BALER (A64278)
JOHN DEERE 467...
2010 Chevrolet Express 3500 Dive Team Cargo Van (A64556)
2010 Chevrolet...
2016 Great Dane 48ft. T/A Refrigerated Van Reefer Trailer (A64556)
2016 Great Dane...
2004 JOHN DEERE 750C LT SERIES 11 CRAWLER DOZER (A65053)
2004 JOHN DEERE...
