Snow Attachments Snow Plow
/ Snow Plow #1
Bx 23
Eastern Maine
2005 Kubota BX 23
First time to this site. I'm in the process of attaching a 6'9" fisher plow to a BX 23. Has anyone attempted such a thing?
/ Snow Plow #2
Welcome to TBN. :)
Attach plow to the bucket or loader arms?
Do you plan on useing plow cylinders or straight/solid setting for pushing?
Would the Fisher plow be heavy duty or light duty plow?..weight factor.
I believe there thread/threads on such project...Search.
/ Snow Plow
I plan on removing the bucket for weight reduction and making a push plate system to drive the plow into.
I will use the plow cylinders for angle by disconnsting the bucket dump hydro.
The plow is a fisher LD 6'9"
/ Snow Plow #4
What will use to hold the push plate vertical?
Thats seems like alot of plow for a BX IMO.
I would also caution you on the potential loader damage a angle plow can do.
/ Snow Plow
This look like a nice set up.
How do you like it without an angle option?
Can you make a tall snow bank with this...plenty of lift force?
Do you use chains?
/ Snow Plow
Thomas,
member superfast has a nice system
Also found versa-daptor on you-tube.
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
KSI Conveyor (A63689)
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
2008 Ledwell LW48HTHT2 48ft. 40 Ton Hydratail T/A Step Deck Trailer (A64194)
2008 Ledwell...
2018 New Holland C227 Compact Track Loader (A63689)
2018 New Holland...
John Deere 660 Hay Rake (A66408)
John Deere 660 Hay...
