>> MORSE TAPER DRILL PRESS CHUCK ??
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #1
BearKiller
My old CTT-Tools made in Taiwan drill-press, bought nearly 35 years ago, has stood there and drilled a blue million holes in everything from BRNO Model 98 receivers to ring-binder holes in a stack of paper.
The old guy who told me to "not have anything to do with that Chinese junk" went long ago and the press is still going strong.
Enough background; on with the question :
For the last couple years, the 1/32 to 5/8 capacity, Morse Taper 2, Jacobs Taper 3 KEYED chuck has steadily been getting harder and harder to operate.
Just a while ago, when I removed a 3/8" bit, one of the "prongs" stayed down, while the other two went up.
I managed to work it back into place and drill several more holes.
Where can I get a replacement KEYED chuck ??
I see the keyless ones that are the same size at swap-meets all the time for about $45, but I do not really trust a keyless chuck on something so important as a press.
Thanks.:)
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #2
Thanks.:)
Harbor Freight has Morse taper chucks. So do lots of other places.
I recently bought a new chuck for a benchtop Delta infinitely variable speed drill press because the chuck was getting really hard (nearly impossible) to use and lubrication didn't help. After I bought the new one I gave the old one yet another thorough lubrication and ran it all the way open and closed a couple times and of course it works fine now. so I have a new spare.
$7.99 for a 1/2" MT2 Mini-Lathe Drill Chuck 42340-0VGA (HF item number)
Got this info at www.hareborfreight.com You could look at Northern tool, Grainger, etc.
Pat
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #3
OE chuck here http://www.use-enco.com/CGI/INSRIT?PMAKA=290-1320&PMPXNO=951435&PARTPG=INLMK3
It is back ordered, but would this work for you ?
Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
There is also this one (chuck only JT3) called a "precision" type Enco - Guaranteed Lowest Prices on Machinery, Tools and Shop Supplies
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #4
I got one for my old Harbor Freight press off Ebay a few years back. There were several to pick from.
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #5
I bought a pretty good drill press but it had a lousy keyed chuck. Somewhere on eBay I found a keyless chuck and its the best thing I ever could have done. I found out you need to have a pair of chuck remover thingies that are like 2 wedges that you push in to remove the old chuck. Got them from Graingers. But its a 1/2" now. Was 3/8 before. Very pleased with the result.
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #7
I've never had any success with keyless chucks, but then I drill steel with drills up to 1" x 1/2" shank.
Even a Jacobs chuck struggles to hold the larger drills.
I don't know why they don't make drills with a hex shank like the screwdriver bits.
With a belt driven drill press nothing disastrous could happen - could it?
Pat
Thanks for the info.
I got two of that exact same chuck on sale for 6.99 each.
They are Morse Taper 2, and they do fit the Morse socket on my press, but those are lathe chucks and lack a very important part that drill chucks have = the "drive key" that is on the small end of the taper that engages a slot inside the arbor, thus preventing the chuck from spinning inside the arbor.
The reason that drive key is absent on a lathe chuck is so the chuck will spin if a tool caught in the stock being turned.:)
That $90 Jacobs would fit the bill nicely; I don't think I gave $90 for the entire press when I bought it new.:rolleyes:
On a closer examination, that is only the chuck and I would either have to somehow use my "taper" or buy another.
I have never had any experience separating the taper from the chuck or installing the chuck on the taper; I wouldn't know where to start.
I have swapped tapers in the drill itself many times, as I bought a five-gallon bucket full of Kosmoline-coated military surplus Morse Taper drill-bits at an auction long ago; the smallest is 3/8 and there are several very large ones in there also, I think up to 1-1/2--they are huge.
I used to actually have an ENCO catalog, but I had forgot all about them until you posted that link.
Thanks.
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #9
To get one from HF, take the part number from the manual and call customer service. They stock some common parts. If they have to order it from China, pass on that because it may take months to get it.
The first one actually has a 3/4 " chuck. Edit: and an MT3 shank - oops.
http://www.harborfreight.com/manuals/39000-39999/39955.PDF
http://www.harborfreight.com/manuals/43000-43999/43389.PDF
This one from Enco is on sale. Might as well get a new shank too, less than $5.
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #10
to get the shank out of a chuck gold the chuck in one hand tight, hit the side of the shank hard several times with a brass or copper bar, it takes a few hits but works
Brad Blazer,
How did you access HF owner's/parts manuals ??
I have tried different times on different subjects and never been able to find them.:confused:
Thanks.:cool:
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #12
Brad Blazer,
Thanks.:cool:
Go to the item listing:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
and scroll down to the green button that says "download product manual"
On the next page you will have to click on the item number. For discontinued items, the manual may still be available. Just edit the item number in the manual's address bar. You may have to edit the range or pick a manual with a closer item number to start with.
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #13
Get a decent quality keyless chuck and you will never regret it! I use one on my mill (1 1/2 hp BP clone) and I have drilled holes up to an inch and a quarter with no slippage unless I got aggressive on the feed.
You're very right allenr, larger sized drills certainly should have a hex shank, especially ones over 1/2. I have milled 3 flats on some shanks on larger drills for myself and for a friend, easy to do if you have a mill and semi universal dividing head! Sure makes a huge difference in the holding power a chuck has to develope to prevent slippage!
Tangs, or "drive key" as you call it, on Morse tapers are not there for "holding power". The taper itself, combined with an axial load, is what generates the holding power. IF the tang on the drill bit can engage the bottom of the socket on a DP, it definitely adds to the holding power, but it isn't the main force by a long shot. (Try milling with a MT endmill and the radial load will walk the taper out under all but the lightest loads. MT endmills need to be restrained with a drawbar.) On another forum quite awhile ago they did the math which proved the tang did not have the physical strength to prevent the taper from spinning. It's soft, and has little area, just the shoulders of the tang, bearing on the spindle and would twist off under a heavy load. They are there to give a wedge shaped drift something to work on when you want to remove them from a female M.T. socket (when they cannot be tapped out from the end) without damaging the end of the taper...damage which could very well prevent it from seating properly into the socket the next time it was used. A wedge shaped drift is placed through the tang slot in the DP spindle and quill between the end of the tang and rear end of the slot, and struck with a hammer which forces the MT out. On lathes, you can reach in through the spindle to tap the MT out of the headstock end and on the tailstock end, cranking the barrel all the in back brings the MT into contact with the end of the screw and forces it out that way.
That is the most wrong statement I have ever heard concerning a lathe. YOU DO NOT WANT A MT TO SPIN IN EITHER THE HEADSTOCK OR THE TAILSTOCK!!! Spinnning in a socket, (just once is enough!) can damage it by raising burrs, especially if it is not a hardened socket. A soft socket can be repaired by judicious use of the appropriate sized MT reamer...repairing a hardened sockets is another story,but it can be done. Cleanliness of both the male taper and the female socket is also of utmost importance before seating the drill into the socket. Wiping both with a lint free cloth to remove any coating of oil isn't over kill. A VERY TINY bit of foreign material in the female socket is enough to cause problems. Dings in the male taper can raise metal and you should check for that and use a slipstone to remove it. The fit between the male and female parts should be as perfect as you can get it. If it isn't, the taper does not seat properly and if it doesn't seated properly, it doesn't develop it's full holding power and the probability of slipping is very high, which means it will probably raise burs and the whole Catch22 situation continues.
A little error in wording, MT are not held in a chuck on a lathe, they usually either go directly into the spindle which would be a female MT socket or you use a MT adapter, usually to size down a size. E.g. from #3 MT to #2 MT. Usually a MT drill bit would be held in the tailstock, which is often one size down from the headstock size.
The fact that you can use a MT in a lathe which has no provision to drive the tang pretty well also negates the idea that the tang is a driving device. However, it is also prudent to use a lathe dog to give backup holding power to the bit if you are doing a heavy cut. It's easy to do on the tailstock side and with a faceplate on the spindle, also easy, and an ounce of prevention is definitely worth more than a pound of cure in this case.
Thanks for straightening me out on the tang business.
It appears that my poor old General Shop teacher has led myself and 13 other poor souls along a mis-guided path and caused us to believe wrongly all these many years.
Right or wrong, at least I remembered his instruction all these many years.:)
So, then I can use the two HF Morse Taper 1/2" chucks in my press and drill satisfactorily, but then lacking the tang, not be able to pop them out with the little wedge thingie and be stuck with one in there forever, right ??:confused:
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #15
Good idea.
I have a cheap Taiwanese mill that is mainly good for breaking end mills (yes I use a drawbolt).
But I also have grinders and an emery wheel, I might try some precision grinding!
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #16
Yeah BearKiller, I was also at one time of the opinion the tang was there for "holding power" but I was educated and convinced otherwise by very well presented arguments to the contrary. Apparently it is a bit of an "old wives tale" (or should that be "old machinists tale"?)!
As far as getting the tangless arbors out of your DP, could you carefully weld on the very end to make an extension long enough for the wedge shaped drift to contact? As long as it didn't interfer with the solid fitting of the taper into the socket, it should work. Welding on the end shouldn't warp it.
Sometimes it doesn't take all that much to get a MT to release, just a few well placed whacks on the side of the chuck will pop it lose, but sometimes it's like they are one piece with the spindle! Just don't use a temperature difference between the two when you install them or they REALLY get tight, its almost like a press fit!
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #17
You get what you pay for! Don't expect a a lot from a poor quality chuck. I have used a number of import low dollar drill presses over the years. Almost all of my frustration has been with the chuck.
A top of the line Jacobs 16N ball bearing super chuck which can open to 0.630 will last forever and will not slip. A new one is pretty pricey. But a used on in great shape can be had for under $90 or so on eBay.
I have domestic two drill presses the larger of the two has an 18N chuck that mounts to a MT3 socket on the quill. I have not had an issue with up to a 1-1/2" high quality bit with a straight 1/2" shank. I also use MT shank drill bits as well.
There are also some very high quality hand operated chucks available as well, although I have not had an opportunity to use one myself.
Also starting with the correct size pilot hole, proper feed rates, as well as having a properly sharpened drill bit make all the difference.
/ >> MORSE TAPER DRILL PRESS CHUCK ?? #18
I think I bought mine from Grizzly. Sometimes you run up on them at auctions.
Why I don't know, but I often forget the existence of GRIZZLY when looking for tools.
I even have a big thick GRIZZLY catalog around here somewhere.
I will see what they have.
Thanks.:cool:
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
Clubcar (A64557)
Clubcar (A64557)
2012 Freightliner M2 106 S/A 14ft. Cab and Chassis Truck (A64194)
2012 Freightliner...
2019 John Deere 314G Compact Wheel Loader Skid Steer (A64553)
2019 John Deere...
1999 Trailmaster Aluminum 407 T/A Chemical Tanker Trailer (A64194)
1999 Trailmaster...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
