New Drill Press
/ New Drill Press #41
Not what the OP was asking for but as some may have mentioned an electric variable speed on the drill press is very nice. I have one with a rheostat and DC motor that I bought from someone . Very usefull when drilling 1/2" holes or larger holes. Also has reverse. Search around as there are many articles about how to install a variable speed treadmill motor on a drill press.
I use a 50a bridge rectifier ($5) and a HFT router speed control ($20) back & forth between two DC treadmill motors on re-powered shop machines. No cpacitor is used on the DC output as it would defeat the PWM operation that gives good torque at low RPM/volts vs say a rheostat, carbon pile, or autotransformer w/rectifier.
/ New Drill Press #42
I might be in the market if either of you are close and still have one you’re looking to part with-thanks.
I am. I'm on the other side of the state but I get out your way often. I own 154 acres of hardwood hunting ground north of GR, just south of Big Rapids so I'm up and down 131 all the time.
/ New Drill Press #43
The issue with buying a used vertical mill (like a Bridgeport) is, inherently, people quit taking care of machines when they plan on selling them and rebuilding a head on a Bridgeport or a Lagun or a Wells Index isn't an easy task. The bearings (4 sets in a Bridgeport) are ABEC Class 3 bearings and the preload has to be set correctly or you destroy them plus disassembly is complex. Been to many machinery auctions and passes on many machines because of the work involved in making them right because they were neglected.
Why I buy new. I take care of my machine tools, treat them like my kids. TIR on any spindle is paramount to me.
/ New Drill Press #44
I have a Grizzly 20” and it meets all the requirements you laid out. I have been using it for about 15 years with no issues. FYI used forstners and hole saws in excess of 2”
/ New Drill Press #45
I shopped a long time before I found a good used machine. IMO there is no new "good" drill presses that are affordable. If you have the money, great. If not. Shop for a used Ellis, Clausing,
Walker Turner, Delta Rockwell, Atlas, Craftsman...
/ New Drill Press #46
My last vertical mill was over 25 grand and the last surface grinder I bought was 7 grand. I purchased a couple floor lathes at Technical school auctions because they were used very little and the LeBlond Servo Shift I bought still had the cosmoline on the bed ways. I consider LeBlond to be the paramount of toolroom lathes.
I do have one offshore built floor lathe, a 16 x 60 geared head, fully tooled Taiwan machine and I was surprised it was as good as it is. Got the machine complete for under a grand. Even has a pressure lubed geared head and quick change (Metric SAE and ISO) thread choices. Even has SKF bearings in the headstock. Came with a handwheel closer and 4 chucks, one 3 jaw scroll, a 4 jaw independent, a 6 jaw scroll and an 8 jaw oilfield style and the head is D1-4 too. Full set of collets and a couple Jacobs taper chucks.
/ New Drill Press #47
I guess the op didn't like my asking price on the Craftsman / Atlas drill press, but I won't give it away as it's not in the way anyway. I think 500 bucks for a drill press of the caliber with zero spindle runout and a drill press vise in pristine (as in no rust anywhere) and prefect working condition is very reasonable and I'm only offering it because I don't use it enough to keep it.
If anyone is interested that is my price and I'm very firm on it.
/ New Drill Press #48
No wonder mine sold instantly, I sold it for what I had into it, and it was a lot less than 500.
SR
/ New Drill Press #49
I have an older Craftsman DP that I bought new. It was one of my fist purchases of a tool for myself. I paid $600 for it and it was the largest they sold at the time. But now that I'm more into woodworking I'm finding that I need one for metal working and one that's free of cutting oil for wood. Sooner or later I'll find an older mill. Even if the bearings aren't in perfect shape or there's some runout it'll still be better than my C-man. Just trying to use a 1/2" endmill to make a countersunk hole for a allen head (not flat) screw is enough to make the cast iron flex. At least with bad bearings you can replace them if needed. Not much you can do about flexing metal.
/ New Drill Press #50
SR
Inflation has devalued the dollar consequently, things cost more.
You need to get after yours with some steel wool (000) and an oily rag...lol
I might put it on Facebook Marketplace. Who knows. Nit all that motivated to sell it anyway. The thread just jogged my memory, nothing more.
How about a well kept 16 x 60 geared head toolroom lathe, completely tooled (aloris BXA tool post) for say 4000 bucks? You get to move it too. Weights about 3500 pounds.
/ New Drill Press #51
No, actually I don't...
The "pretty one" (read yours) is still sitting unsold, The one that's for GO instead of SHOW, is sold and being used by someone else...
My tools work just fine and get used often...
SR
/ New Drill Press #52
SR
... and rust too. :p
I surely don't have to sell (drillpress) anyway or the lathe or anything in the shop for that matter. None of mine are corroding either.
/ New Drill Press #53
Hi Im looking for ideas and suggestions for a new drill press to replace my current porter cable floor model (its only three years old but is currently struggling and the belt tensioner broke again). It will mostly be used for drilling steel I use it extensively daily when I'm doing a project than sits for weeks unused.
Minimum 4" spindle travel, 5/8 chuck, like it to be a 20" model, minimal runout and heavy duty enough to use 1" plus hole saws and bits. would like it to be 1k or less pains me to say this but seriously considering the harbor freight 20" drill press but sold out til sept. Does not need and don't want laser alignment.
I have a Clausing (German mfg.) that I bought used from an industrial tool/machinery supplier.
It is a magnificent piece of machinery!
Look for quality used stuff.
There is some very fine yet relatively inexpensive, used machinery out there.
/ New Drill Press
2272EVS1-110 - Clausing 20” Floor Drill Press, 50-2000 RPM Inverter Variable Speed 115/1
Wonder what this would cost?
/ New Drill Press #55
There's several on ebay priced ~ $2k and up. btw, I like 5030's offer, if priced for like new condition. Beats what HFT has for more $$. You'd want to be sure you're ready for 3Ph power as often required with higher end equipment.
/ New Drill Press #56
The minimum speed of my Clausing model 1671 is only 330RPM, and I note that even though I bought it used, 30 years ago. it has a current value of $1,500.
A new Clausing model 2272EVS-1-110 should have a retail price of around $5400.
Try to be patient, and look for a used drill press.
/ New Drill Press #57
A halfway worn out Bridgeport style mill makes a great drill press. Even better if it is 3 phase because you can put a VFD on it and have even better speed control and run it off of 220/240 volts. Only real downside is the weight, but a tractor can help with that.
/ New Drill Press #59
I set both of mine with a Harbor Freight roll around engine hoist.
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
Ford Truck Tire and Rim (A65640)
Ford Truck Tire...
School bus (A64194)
School bus (A64194)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A65053)
KNOW BEFORE YOU...
Club Car Gas-powered Golf Cart (A66408)
Club Car...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
