Rotary Cutter 5' Rotary Cutter On The Cheap
/ 5' Rotary Cutter On The Cheap #1
Ductape
Elite Member
Central New Hampshire
Kubota B3030HSDC
Yesterday I picked up a used 5' rotary cutter that was on CL. Made by Modern Ag. Products in Beaumont, Texas. Part of their 'Sunshine Line', which I'd guess is their lighter duty units. I was somewhat surprised that they are still making rotary cutters when I googled them when I got it back home ( Dragon Products ).
The previous owner told me it was sitting in the yard when he bought the house 3 1/2 years ago, and he'd never used it since he didn't own a tractor. The driveshaft was rusted so that it didn't telescope, it needs a little welding, and how about that 'shear bolt' for driveline protection ! :eek:
/ 5' Rotary Cutter On The Cheap #3
A little TLC and that RC will be as good as new!
I think all rotary cutters need a little beefing up in the area where that is cut.. A rotary cutter leads a tough life.. It's amazing they stand up as well as they do!
At least your gearbox is well protected! LOL
I spent the afternoon fixing a few of the problems. Lotsa jizz-bang and a little work with a hammer got the PTO shaft seperated. Sanded the rust and greased it up like a proctologist. Replaced the square headed 'shear bolt' with a stainless bolt till I can get a slip clutch on it. Checked the gearbox..... filled with grease, as I sort of expected.Changed one of the zerks and greased up the u-joints. Hooked it up to the tractor and checked the PTO shaft for length.... it was good. Then I tried it out and I gotta say it worked well :) !! I love Craigslist ! :D
It looks like I can hammer it somewhat straight and weld the tears up. If not, I'll cut out that section and weld some steel in.
No one will be acusing me of being a metalworker antime soon....... but I did stitch up the cracks and tears this afternoon. :cool:
/ 5' Rotary Cutter On The Cheap #9
Looks good!
That's not an easy repair! Once metal is torn like that, it stretches, making it nigh on impossible to make a flawless repair..
Ya' done good!
Are you going to paint it??
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
2016 Jeep Compass SUV (A61569)
2016 Jeep Compass...
2012 HEIL (A60736)
2012 HEIL (A60736)
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2020 MACK GR64FT DAYCAB (A60736)
2020 MACK GR64FT...
CAT B30 HYDRAULIC HAMMER (A60736)
CAT B30 HYDRAULIC...
