JD 5220 No Start ?
/ JD 5220 No Start ? #1
Alpine7
Dayton TN
JD5220,MinMolineZ,FarmalA,KubotaFZ2100,Speedex24
The Fuel Lines Were Cracked And Leaking On My 01 JD 5220
Replaced The Main And Return Lines, Water/Filter Sep.
Having A Hard Time Bleeding The System, Was Worried I Sliped Some Contaminents By. J.D. Manual Says To Remove Bolt From Side Of Injection Pump. Work The Plunger At The Filter Housing Till Fuel Flows From Hole Without Bubbles. Cant Seem To Get Flow!! It Will Slowly Seep Out On Its Own.Pumping Makes No Diff. Pulled Loose The Line To Pump,Fuel Flows Great.
How Much Fuel Is To Run Out Of Hole? Seep or Flow ?Do I Need To WD40 For A Self Bleed Run. Cracked A Line to Injector No Fuel Presure.Looked In Inlet Area For Clog Seemed Very Clean. HELP !!
Thanks Arnie :confused:
BUNDLE OF 4"X RANDOM LENGTHS RED OAK FLOORING (A62131)
BUNDLE OF 4"X...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
2021 Kubota SVL75-2 Track Loader (A63118)
2021 Kubota...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
4 Shelf Rolling Cart 6ft x 3ft (A61166)
4 Shelf Rolling...
