K&N Air Filter for CK30
/ K&N Air Filter for CK30 #1
KBEAT
Noticed today that K&N has an air filter listed for the CK30 for about $38. Anyone have any thoughts about using an oil saturated filter on these tractors ?
/ K&N Air Filter for CK30 #2
I would NEVER use a K&N type filter on a tractor or machine that typically operates in very dusty environments.
/ K&N Air Filter for CK30 #3
I would think for the same price or maybe a few bucks more you could buy the recommended air filter from your dealer?Just a thought.coobie
/ K&N Air Filter for CK30 #4
If you let more air into any engine without increasing the output through the exhasust system you willl have accomplished absolutely nothing except demonstrate the placebo effect, car or tractor. In this case with a tractor in a dusty environment I would rather be hit in the teeth with a coat hanger than use a K&N on my equipment.
/ K&N Air Filter for CK30 #5
Not quite, the exhaust system is not always designed to be at it's maximum flow for that specific engine. That is to say that the engine is not utilizing the full extent of the exhaust's capabilities. On just about any vehicle made today, a K&N or other free flowing filter will increase HP due to the fact that the intake is always the first bottle neck.
With that said, adding air to a diesel engine does not make more power without adding fuel. An electronically monitored fuel injected vehicle will compensate with more fuel but the majority of diesel tractor engines will not. So it will most likely do nothing to your tractor but it is a lifetime cleanable filter that is much cheaper then buying replacements...
/ K&N Air Filter for CK30 #6
I looked for a K&N air filter before but couldnt find one. Now that I know one is available I will buy one quick. I have used these filters on my trucks for years and they work great. I dont think the "dust factor" is a big concern. The K&N beats the cheap paper filters any day of the week. You can save alot of money in the long run too.
Coobie, it's not a question of cost so much as whether the oil/cotton filter would filter better than the paper filter. K&N has a pretty good reputation, I wouldn't think they would get into agricultural without some confidence in their product. My Cub Cadet garden tractor has a foam pre-filter that is oil saturated and that filter has to catch 90% of the dirt before it gets to the paper element. Just trying to incite conversation among the troops :).
/ K&N Air Filter for CK30 #8
Not quite, as you said this depends on the choke point. If the engine is currently starved for air by the filter but has plenty of fuel under high load conditions then simply removing the filter (or installing a K&N, same thing) will allow enough air for complete combustion of the extra fuel which will create power. Just imagine a plugged up air filter and how this creates black smoke which is wasted power.
I would NOT use a K&N on my truck and especially not on my tractor.
/ K&N Air Filter for CK30 #9
I understand,I have AFE stage II air intake on my 2004 cummins diesel this filter you have to also lightly oil.I recently bought a Air filter for my 2008 Kioti Dk40se for around $52.00 bucks,my Afe stage II was $400 with pre-filter sock.LOL.coobie
/ K&N Air Filter for CK30 #10
What happened to the good ole days of a oil bath air filtration systems. I have those on a John Deere 730 Diesel and a 10" chipper. They have plenty of air flow and nothing gets through them. Just change with a quart of oil every 6 months to a year. There is a pretty good article here for those that are interested. Yesterday's Tractors - Oil Bath Air Filters
/ K&N Air Filter for CK30 #11
So it will most likely do nothing to your tractor but it is a lifetime cleanable filter that is much cheaper then buying replacements...[/quote]
Is it really cheaper? If you buy the K&N cleaner stuff and then their oil that goes on the filter to make it work, is it really any cheaper than a std paper replacement filter? I don't know as of today, but years ago it was not.
/ K&N Air Filter for CK30 #12
As is true with many all-encompasing statements, this is not always true. It has been proven time and time again that adding a turbocharger to a mechanically injected diesel will increase HP without touching any injection pump settings.
/ K&N Air Filter for CK30 #13
RickB, I guess that I should have quoted only the highlighted area as I have just taken care of that. I was not responding to the air to diesel engine thing. Sorry :eek:
/ K&N Air Filter for CK30 #14
After a re-read, I see that was actually a quote from Dmace, not you. Not sure how I made that mistake, but I did. Sorry about that.
My response stands, though.
