K&N Air Filter for CK30
   / K&N Air Filter for CK30 #11
So it will most likely do nothing to your tractor but it is a lifetime cleanable filter that is much cheaper then buying replacements...[/quote]
Is it really cheaper? If you buy the K&N cleaner stuff and then their oil that goes on the filter to make it work, is it really any cheaper than a std paper replacement filter? I don't know as of today, but years ago it was not.
   / K&N Air Filter for CK30 #12
MtnViewRanch said:
With that said, adding air to a diesel engine does not make more power without adding fuel.
As is true with many all-encompasing statements, this is not always true. It has been proven time and time again that adding a turbocharger to a mechanically injected diesel will increase HP without touching any injection pump settings.
   / K&N Air Filter for CK30 #13
RickB, I guess that I should have quoted only the highlighted area as I have just taken care of that. I was not responding to the air to diesel engine thing. Sorry :eek:
   / K&N Air Filter for CK30 #14
After a re-read, I see that was actually a quote from Dmace, not you. Not sure how I made that mistake, but I did. Sorry about that.
My response stands, though.
JOHN DEERE 750 GRAIN DRILL (A58214)
JOHN DEERE 750...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
60in Forks (A56857)
60in Forks (A56857)
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
2020 DRAGON ESP...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
