Lower link hiccup
/ Lower link hiccup #1
redka
Middle GA
My JD 5103(224 hrs) developed this hydraulic problem with the lower links. With or without implement hooked up the lower links will drop about 1/2 inch then come back up. Without an implement it cycles about once/3 seconds. With implement attached it's twice/second.
Is this something I can fix, or does it need to go to the shop?
Any advice appreciated. Thanks.
/ Lower link hiccup #2
I'm not real familiar with the 5103 hydraulic system, but it sounds like it has a small leak in the lift cylinder. As it leaks down below the setting of your lift lever, it is trying to correct itself and raise back to the preset point. Since this is usually caused buy an internal leak, the cycle just continues to repeat. Sad to say, it usually only gets worse.
Maybe some of these Deere guys will hop in here with better news than mine. I have more experience on older Ford and Kubota than anything else.(Retired from tractors in 90) Service Manager/Shop Foreman/Mechanic, same dealer for 22 1/2 years. With a Deere dealer in the same town, we didn't see many green tractors.
I hope it's just something simple. :)
Mike
/ Lower link hiccup
Mike, sounds logical. I'll be watching for some other replies, and will be talking with the local JD shop man. Thanks.
/ Lower link hiccup #4
Here's a quick way to check if it is a leak in the the lift cylinder, control valve, or plumbing. Raise the implement all the way up and then shut off the engine. Watch for the 3PH to slowly drop. It should drop all the way down, but may vary in drop speed depending on the seal with the inner walls of the cylinder. Most likely it is a leak in the lift cylinder as Mike suggested.
One other thing is that the 3PH is often the last thing in an open-center system. That means that if you run a remote or FEL, while they are operating, the 3PH will drop because it has no inlet pressure. This could cause the 3PH to really jump when you return the FEL joystick or remote lever to neutral and open the flow to the 3PH.
/ Lower link hiccup
Here's a dumb question...in the first procedure above, when the engine is shut off, should the arms stay up if there is not a leak problem?
/ Lower link hiccup
Update- got tractor back from shop today. The problem was a defective part in the hydraulic system...a cast part associated with the rockshaft with holes for fluid passage with a o-ring seated at each hole. The surface of this part was ground very smooth except one spot over one of the o-rings. There was a small gouge there like the grinding machine slipped or something. That o-ring held for three years, eventually failing due to the gouged metal surface. JD replaced the part with a new one, no charge to me.
/ Lower link hiccup #9
Glad it was a quick fix. Now you can get back to having some fun...er...uh...working. :D
Sounds like you have a good dealer. I like hearing about dealers that step up and do what is right. Those are few and far between.
Mike
/ Lower link hiccup
Mike
I was thinking about it later with the warranty already expired, they could have really socked it to me for probably $1500-$2000. But the part was clearly botched in the milling process, and it took 221 hours for it to finally break the o-ring.
/ Lower link hiccup #11
My 5103 is doing the same thing yours did. Do you have a part number for the o rings? Can you point me to where they go.
/ Lower link hiccup #12
My 5103 is doing the same thing yours did and it is getting worse. Do you have a part number for part they replaced or a name for it? Can you point me to where they go.
2 new 10'' Pallet fork extensions (A61567)
2 new 10'' Pallet...
KAESER COMPRESSOR (A60736)
KAESER COMPRESSOR...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60352)
2012 International...
2003 POLAR TANK (A60736)
2003 POLAR TANK...
2018 CATERPILLAR 906M WHEEL LOADER (A62129)
2018 CATERPILLAR...
ASSET DESCRIPTIONS & CONDITION (A59908)
ASSET DESCRIPTIONS...
