Sharpen saw blades?
/ Sharpen saw blades? #1
Bedlam
Just curious, I see HF has a sharpener machine for circular blades.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
But I was wondering if anyone had attempted to sharpen theirs with the angle grinder, and what results they got.
I am looking to sharpen , as I use it strictly for demolition cutting ,(so no need to be super sharp).
Also curious as to if this sharpener at HF will dot he carbide blades .
Al
/ Sharpen saw blades? #2
Good Mornin Al,
For $60 bucks I dont think you could go wrong ! JMO !
Look at it this way, even if you only got two sharpenings out of each carbide blade, youve probablly paid for the unit right there ! ;)
Im certainly am no expert but I have spent over 36 years as a toolmaker, and that unit looks like it will remove a small amount from the face of each tooth, thats all you really need to get some more life out of each blade !
The worst case scenario, is that you would make a deragotory post in another Harbor Freight thread on this forum ! :)
/ Sharpen saw blades? #3
hello i agree that will only take off a little bit i dont like the dimond weel they dont last to long would like to see carbide weel grean color.
/ Sharpen saw blades? #4
I have the sharpener. Haven't used it yet though, setting it up is low on the list.
Not sure I'd buy it again - Forrest will sharpen professionally for $7 a blade or some such, which strikes me as quite fair.
/ Sharpen saw blades? #5
Al
Sharpen mine all the time with a grinder, been doing it for years, before that I'd use a hand file. Never had a problem just take a small amount at a time and they should be fine.
20/20 Do you do the carbide blades with grinder as well?
I am assuming that this HF machine has the right wheels to do casrbide blades , yet I dont see any reference to it.
/ Sharpen saw blades? #8
Here you go Bedlam. Use this 20% off coupon and get it even cheaper. :D
3609 RetailB
That would save you another 12 bucks.
Mike
John Deere 4960 Tractor (A64047)
John Deere 4960...
2014 Jarraff Geo-Boy Mulcher (A64047)
2014 Jarraff...
BUNDLE OF APRROX (15) 3'X30' METAL SHEETS (A62131)
BUNDLE OF APRROX...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A63118)
PENDING SELLER...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2019 WACKER NEUSON EZ36 MINI EXCAVATOR (A62129)
2019 WACKER NEUSON...
