Sharpen saw blades?
   / Sharpen saw blades? #1
Bedlam
Just curious, I see HF has a sharpener machine for circular blades.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
But I was wondering if anyone had attempted to sharpen theirs with the angle grinder, and what results they got.
I am looking to sharpen , as I use it strictly for demolition cutting ,(so no need to be super sharp).
Also curious as to if this sharpener at HF will dot he carbide blades .
Al
   / Sharpen saw blades? #2
Good Mornin Al,
For $60 bucks I dont think you could go wrong ! JMO !
Look at it this way, even if you only got two sharpenings out of each carbide blade, youve probablly paid for the unit right there ! ;)
Im certainly am no expert but I have spent over 36 years as a toolmaker, and that unit looks like it will remove a small amount from the face of each tooth, thats all you really need to get some more life out of each blade !
The worst case scenario, is that you would make a deragotory post in another Harbor Freight thread on this forum ! :)
   / Sharpen saw blades? #3
hello i agree that will only take off a little bit i dont like the dimond weel they dont last to long would like to see carbide weel grean color.
   / Sharpen saw blades? #4
I have the sharpener. Haven't used it yet though, setting it up is low on the list.
Not sure I'd buy it again - Forrest will sharpen professionally for $7 a blade or some such, which strikes me as quite fair.
   / Sharpen saw blades? #5
Al
Sharpen mine all the time with a grinder, been doing it for years, before that I'd use a hand file. Never had a problem just take a small amount at a time and they should be fine.
20/20 Do you do the carbide blades with grinder as well?
I am assuming that this HF machine has the right wheels to do casrbide blades , yet I dont see any reference to it.
   / Sharpen saw blades? #7
HF specifies that it has a diamond blade, so it should work.
Includes 4" diamond wheel, 4" emery wheel,
from the link.
   / Sharpen saw blades? #8
Here you go Bedlam. Use this 20% off coupon and get it even cheaper. :D
3609 RetailB
That would save you another 12 bucks.
Mike
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
1995 GDY Hurricane Fun Deck 21' Boat (A53316)
1995 GDY Hurricane...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
2000 Ford F-150 Ext. Cab 4x4 Pickup Truck (A55788)
2000 Ford F-150...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
