home made pm, low voltage
/ home made pm, low voltage #1
meltdown1a
I just made a pm generator, it has 9 coils 80 windings of #15 spaced in a circle inside a 12" diameter.
I have a board with 12 rows of magnets. this is turned by a Savonius.
With all of the coils hooked in series I'm getting about 2v at around 200rpm.
I got it up to aout 1500 rpm and I still only got about 8v.
I have put washers under the coil to help draw the magnetism though the coil. I have 2 steel plates coming to replace the wood rotor.
It seems that I have all the coils in phases although I had to reverse the three a phase when hooked in series and it seems reversed again when running 3 phase.
Should I proceed with these items or just start over. any Idea's will help
/ home made pm, low voltage #2
Some Questions:
What kind of magnets?
How much space between magnets and coils?
Actual size of coils?
Size of magnets?
Have you measured the output of a single coil at any RPM?
What did you use to insulate the wire in the coils?
How are the magnets orientated to the coils?
A picture might answer most of these questions.
A combination of coil, magnetic field and ammount of time the field is exposed to the coil determine the output voltage. The wire gauge/diameter usually determines the current capacity out of the coil, to the extent the fixed magnetic field can maintain the voltage under an applied load. The magnets in close proximity should enhance the applied field, so closer spacing should = more voltage. IF the field is not orientated properly to the magnet, it may be receiving a weak field. If the coils are internally shorting, you have effectively a coil with fewer windings, so less voltage output. It the coils are wired incorrectly, the output of one coil could be cancelling out another. A second plate with another set of magnets(coil plate sandwitched between magnet plates) will enhance the field.
Did you design this yourself, or are you following some plan?. IMO, following a proven design with proven components is the best way to build your first one... The Otherpower forum has a wealth of information on this type generator. This is a video of one of my favorites. They also did one on a listeroid slow speed diesel.
YouTube - Otherpower Steam Generator
How did you make your rotor/turbine? i havn't heard anything about a savinious(sp?) rotor in a long time.
Good Luck
/ home made pm, low voltage #4
PM= Permanent Magnet. Uses fixed high density magnets to generate the magnetic field instead of using some of the generated power to build a magnetic field in a rotor like a traditional alternator/generator.
Not using this power for the field means greater generation efficiency. But since the field is fixed, there is no control of output voltage other than the construction of the generator. Most people use them for wind and hydro where the power source can be unpredictable anyway, and convert it to DC. The DC is then regulated and used to charge batteries, or sometimes back feed the grid via a grid tied inverter...
/ home made pm, low voltage #5
meltdown1a, I've no experience making a PMG but have printed these www.scoraigwind.com/pmgbooklet/itpmg.pdf plans & it's on my to do list. There may be something here that helps. Please post your solutions as you find them. MikeD74T
Here are some pictures and details of my project. Since using the steel plate and double the magnets I have raised my voltage by one and a half volts to a whopping 3.5 volts
Go Solar Canada And Wind To. Any advice will be appreciated.
Thanks
Dan
/ home made pm, low voltage #7
Dan, Did you look at the troubleshooting section of the Piggot pdf? It seems to suggest that coil tightness & placement, as well as # of turns /wire size, makes a big difference. They're saying you should see 4 vdc at 60 rpm. What reference are you building from? What are you using for magnets?
I've got a nice brook on my property so am looking to build a raft mounted paddle wheel with a PMG driven initially by a 10 speed bike gears & chain until I find optimum speeds. MikeD74T
/ home made pm, low voltage #8
In the electically theory you would have to series the windings to increase the voltage if all the magnets and coils are in correct phase and physical relation. but that would also reduce the current.
tom
/ home made pm, low voltage #9
Ok, here's a few things I notice... First, since you have 3 square magnets in a row for each "magnet" you would be better served to have 3 rows of smaller coils where each magnet passes above one coil.
Second: Not sure of your magnet phasing from the picture, but going around the circle from any arbitrary point the magnets should be N-S-N-S, etc so that each other magnet is flipped relative to the next one around the cricle. The idea is never to have two magnets next to each other with the same pole facing up. This will mean you need an even amount of magnets.
Third: Those look like awfully small magnets, and the washers under the coils aren't going to do much. I would suggest using a finer gauge wire and winding a bunch more turns and wind them around a thick bolt, section of steel rod or rebar (or ferrite core if you can find it). The idea of having a ferrous metal core to a coil is to concentrate the magnetic flux within a smaller diameter and get more field lines passing through each coil.
Have a look at this project Hamster-Powered Night Light for more ideas.
/ home made pm, low voltage #10
I think your magnets are way to small for those coils. Just like the same reason a conventional generator has low voltage, not enough field is being generated. In the ones I have seen the internals of, the magnet face area is easilly as large as the coil. The field those small magnets are creating is just not large enough to induce much in the coils. Here is a link to some more detailed pics of the otherpower steam engine PMG being built. Note the size of the magnets in relation to the coils. This PMG also has a magnet disk on either side of the coils. More field = more voltage.
Steam powered Generator
Wow. What a learning experience and great advice. I wasn't sure what to do but this has helped.
Thanks
Ok first, I added another row of magnets to make them 3 thick or 3/8" and I raised it to 4.5 volts at 220 rpm. The reason I'm using these magnets, is that they are the only magnets readily available. I'll be ordering some from the net. If anyone knows a cheap Canadian supplier. The reason they are gapped is because they will fly off if they get closer since if the same pole is up then they repel at the sides. I have checked and all of the poles are correct. I do believe solid magnets will make a difference. the ones I need are 3"x1"x1" or even 1/2" thick.
I have checked and rechecked the coils for sync. When I made them I made sure they all wound the same way, I marked the inside lead, they are wrapped fairly tight so it seems odd the the first of the three phases on all three sets of coils were reversed phase. I think they may be a little thick at around 3/4".
I have 12 poles and 9 coils, this gives me 3 - 3 phase loops. I have everything hooked in series right now by phase, 3 in phase, to 3 in phase to 3 in phase or 1-4-7-2-5-8-3-6-9 .
/ home made pm, low voltage #12
Meltdown,
1 thing I notices is the shaft is supported on 1 end. Ideally, it should be supported on both ends to prevent wobble from wind pressure on your turbine. If that's impossible, then a heavier shaft and bearing will help prevent wobble.
I have a large stack of old hard drives, and they contain 2 samarium cobalt magnets. They're unbelievably strong, and very small. Someone sells them on the web. Just look up "samarium cobalt magnets" or "rare earth magnets"
I use to day dream of using those HDD magnets to build an 8' turbine and integrated generator. It would have has many magnets affixed to the outer edge, and a stator with many coils. I went solar instead.
Hey Bob, The setup I have now is temporary for testing. I hold it straight with a hand held bearing for now.
Yes the hard drive magnets are very strong but I believe the rare earth magnets are stronger. Plus I can get more of them, right now I have 108 magnets at 9.1lb each pulling force, 9 mags in 12 rows, giving me about 85 lb/row. If I replace these with 2"x1"x1" Rare Earth Neodymium Iron Boron NdFeB Block Magnet Grade N42, these have a pulling force of 145lb., These are $10 each and I've already spent $108 on my existing magnets. A lot of money for someone unemployed as I am. But important things first right. He He
Here is an update, I have added another row of magnets giving me 12 magnets per row, this gives me 114lb pulling force for each of 12 rows, I also rewound my coils, I went with a smaller core, made them a 1/2 inch thick and I got 98 turns on each coil now, I have removed most of the washers except the ones directly under the coils, now I'm getting some cogging but not a lot so it runs fairly smooth an easily and I've added a drill to turn it for now. I've gotten it up to 6.2 volts at 200 rpm in series and right now I'm getting about 1 volt for every 33 rpm. I'm hoping a second rotor will double the voltage. With the second rotor I'm hopping to get 24 volts at 400 rpm. The more magnets have a direct response and so did the smaller coils with more windings as does the rpm. I think I'm almost ready to add the other rotor and encase the coil and rotors in resin and then mount it. I wound it up to 1500 rpm and when the magnets flew off it smashed my side mirror on my car, some magnets flew over 30'.
Any questions or suggestions are welcome.
Thanks again for all of the previous comments.
Check out my site for more pictures Go Solar CANADA
/ home made pm, low voltage #15
I looked at your link, and I can't view any of the videos of the rotor(IE says there is a network error).
/ home made pm, low voltage #16
I was able to view the video's OK at about 10:40 PM CDT. Temporary glitch???
If you right click and then save the link
/ home made pm, low voltage #18
My firewall had windows media player locked out for some reason... Looks interesting. I always liked the concept of the S rotor. Low speed, high torque, self starting, self regulating, omnidirectional, easy to build and maintain...
2003 Jeep Liberty 4x4 SUV (A64557)
2003 Jeep Liberty...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
2025 NATIONCRAFT 6X12TA2 T/A ENCLOSED TRAILER (A67148)
2025 NATIONCRAFT...
2014 Chevrolet Express Shuttle Bus (A64556)
2014 Chevrolet...
2022 EZ-GO ELITE...
2019 Lynco Mini Mover Aircraft Tug Cart (A64553)
2019 Lynco Mini...
