Bush Hog 2426 loader/ Grapple
/ Bush Hog 2426 loader/ Grapple #1
millwrightdude
I have a Case IH C50 with a Bush Hog 2426 loader. I would like to install a grapple. I was wondering can the hydraulic lines for the grapple be installed in the loader arms like the lines for the bucket cylinders are? I know I can buy a WR Long kit, But I did not like the price I was quoted for it. Has anyone installed their hydraulic lines for their grapple this way?
/ Bush Hog 2426 loader/ Grapple #2
I followed Island's example and installed a two spool valve for my grapple rather than the diverter like the long kit. I think he did not need to add the remotes though. I was able to install it right next to my loader control so it is very convenient. It cost a only a little less but but gave me greater functionality. At some point I want to get a hydrailic top link, and all I will need is hoses.
My lines run on the outside of the loader arms. I just used some tie wraps to rune my new lines right parrallel with my loader lines. If they will fit in your frame I cannot imagine why you could not run them there. Seem like it woould keep em safer. You will need a fair amount of slack between the the front of the frame and the grapple to allow full curling for picking up sticks.
I ran an old inner tube between my loader arms to help with hose control.
/ Bush Hog 2426 loader/ Grapple #3
That's pretty slick the way those hoses are run inside the loader arms.
Seems like the best method to keep them out of harm's way. If you can do that, great. But if not, it's OK to run them along the inside of the arms too. That's what I did.
You can see the black grapple hoses above the steel loader lines on the loader arm.
I fastened them with rubber lined HD hose clamps.
Turned out pretty clean and a simple installation that way.
Any other ideas. I will need a bracket that I can mount the quick disconnects to. where can I get it? Or will I have to make it? I have not yet decided how to run the lines, So any input would be great
/ Bush Hog 2426 loader/ Grapple #5
OK, You stated "you did not like the price" of the WR Long kit, so how are you going to operate the grapple?
As far as mounting the couplers, you'll need to make it (but it's included in the WR Long kit)...easy to do with a piece of 2 1/2" or 3" angle iron and some bulkhead fittings.
I thought I would run the lines down the loader arms and plug them into the rear remotes. I cant seam to remember how much the WR Long kit was. Mabe someone can remind me
/ Bush Hog 2426 loader/ Grapple #7
The WR Long kit runs about $550. It includes all hoses and hardware, and a new handle for your joystick.
I have tried to install the lines in the loader arms but there is not enough room. So I guess I need to run them down the outside of the arms.
/ Bush Hog 2426 loader/ Grapple #9
Hi Guys, New hear but have been watching and learning from the sidelines. KennyD interesting note about the WR Long kit. Would you say that is a better way to go than piecing the hydraulics together part by part? Just wondering as I am in the process of purchasing a Markham grapple for my 2520. I got a list price from Long for $483.00 not including shipping but, I thought maybe I could do better building my own joystick handle with switch and then buying and mounting the same diveter valve as you did. Don't know yet as to what hoses and fittings would cost. What your thoughts as you have been through this. Thanks!
I wonder what the Bush hog 3rd function valve kit costs?
Any suggestions on how to attach the lines to the loader, other than zip ties?
I like those, but I did not want to weld to the loader if I didn't have too. But I wonder if I drill and tap the loader frame to use those if it will affect the loader strength?
My only concern about welding or drilling into the loader arms is, would it weaken it
I stopped by my local hydraulic shop today and got a few of these. I got the ones for 3/8 hose. I think 3/8 is big enough. What do most people use when adding hydraulic lines on their loaders,Tube or hose, and what size?
/ Bush Hog 2426 loader/ Grapple #17
1/4" hose is usually plenty big enough...unless your running a hydraulic PHD. Grapples, 4n1's and snowplows do not need high flow, and the smaller lines help slow the cylinders down for better control-and it's cheaper and easier to route.
Although I do want to run a hydraulic PHD. So I should stay with the 3/8. I might what to use tubing instead of hose.
/ Bush Hog 2426 loader/ Grapple #19
I don't think tubing for a PHD is a good idea. Whether it is on the bucket up front, or the 3pt out back. PHD needs to swing freely and the bucket/3pt has to move up and down.
3/8 hose should be good enough. If you have to, you can limit the hyd low many different ways.
Well, I have not started this project yet but will need to do it soon. I was wondering where does the WR Long kit mount on a Bush hog 2426 loader. I have been researching this for the last few days. I found that the Bush hog 3rd function kit kit mounts on the loader cross bar. I like that idea. I looks like the Bush hog kit is easy to install because of where it mounts. Then the wire that controls it runs on the inside of the loader frame, which would be out of the way of getting damaged.
Unused 2023 Del Morino Funny 132M Hydraulic Flail Mower Attachment (A66734)
Unused 2023 Del...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2018 Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2018 Ram 1500 4x4...
Has compression. Unknown operating condition. (A64553)
Has compression...
2012 COMPTANK  ACID TRANSPORT TRAILER (A67714)
2012 COMPTANK...
CAT 345CL Sprockets (A68134)
CAT 345CL...
