Tractor Pull!!
/ Tractor Pull!! #21
pilot thats one heavy 28 hp tractor steel must be heavier in china than in korea.
/ Tractor Pull!! #22
A lot of the economy tractors coming out of the orient are made from cast that is not the best quality, so they make it heavier and thicker the same as here 100 years ago. In the wrong place it does little to help a tractor with pulling but will actually hinder it.
When pulling tractors we used to have a rule(guess it's still there) 100 lbs off the front put's 200 on the rear while pulling.
It's kind of like us a little when we were younger we had strong broad upper bodies. As we aged it shifted down into our waist lines. Still the same weight! Just not as strong and benificial!
/ Tractor Pull!! #23
I just don't see how a 28HP jinma can out pull a 50HP Ford. :confused:
I'll hook up with yours if you will mow all my grass for a year. :D
But noway would I hook up against Farmwithjunk... He would pull me from Eastern KY to Western KY. :D
I pulled out a Dozer that a Dmax 3500 and the Ford fail to do. You have to remember my tractor weighs 5,200#, has 4x4, R1's, and diff locks. The Ford just spun the R'1s to China and the dmax could not get a bite. I made a few guys eat their hats that day the county highway guys got the dozer high centered in the road ditch.
There is a video I will try to find of a 22HP Jinma out pulling a large tractor. I will find it.
Chris
/ Tractor Pull!! #24
I have the rears loaded but the tractor weighs 3,200# with me on it. I also have rear wheel weights, 4 front suit case weights, and a 800# FEL.
Here is the data on it. The HP is listed as 25 but its 28. Mine dynoed at 31 on the pto according to the dealer.
Chris
/ Tractor Pull!! #25
I enjoy seeing combines tug on each other. They do that around here before the combine demolition derby.
/ Tractor Pull!! #27
/ Tractor Pull!! #30
The only tractor pulling I do is when one gets stuck in the mud and I have to pull it out. That used to happen frequently when all we had were 2wd tractors. I used to use my second largest tractor for risky operations, always holding the largest one in reserve for when I had to pull it out. That is the price one pays on a mucky bottomland farm like mine in order to get your spring planting done. I aint done no pulling at all since getting a 4wd tractor 4 years ago.
/ Tractor Pull!! #31
If the neighbor KNOWS about pulling you might not want to get into this.
e.g. if he is a guy that "does pulls".
4WD doesn't help, I don't know why that was mentioned.
If he is set up right he will be on the rears only with the fronts about 6 inches off the ground, his drawbar will just about be touching the ground at that point.
Again, it might be a lot more about what each of you KNOW than what each of you DRIVE.
Kinda like Tiger could do better with my clubs than I could do with his (MUCH BETTER) clubs.
/ Tractor Pull!! #32
OMG it looks like an opening and we are getting ready to go again!!!:D
/ Tractor Pull!! #33
4wds don't prevent you from getting stuck. That notion is a laugher. They tend to get you stuck WORSE in WORSE places. BTDT, still use my 2wds anywhere I feel the need to and don't get 'em stuck.
Farmwithjunk, who owns five 2wds, and five mfwds.
/ Tractor Pull!! #34
As mentioned 4 wheel drive does not keep you from getting stuck but it will take you many places 2 wheel drive can not. The problem is if and when you do get stuck it is that much more difficult to get it un stuck.
Chris
/ Tractor Pull!! #35
Chris
Just to add...if you are going into a bad area, it is best to go in with 2 wheel drive, then use 4 wheel drive to get out if needed.
/ Tractor Pull!! #36
4wd actually has prevented me from getting stuck (100% effective for 4 years). I used to get stuck a couple times a season trying to get my tillage done in time for spring planting. You southern folks dont have too worry about it, but up north we got to get our planting done early or we dont get mature crops because of early frosts. It is not a good idea to get into the fields too early but many times 90% of a particular field is plenty dry but the other 10% will do in a 2wd tractor. I wish I wouldnt have listened to that tired old line about 4wd just getting you stuck worse as long as I did. I probably could have gotten my planting done a month earlier for a lot of years if I hadn't. I actually did loose traction in a mud hole one time with my 4wd while discing this spring. That didnt cause me any trouble because I leave the loader on and downsize the disc a bit when getting stuck is a risk. That way, I can simply drag myself out of the mud with the loader when I loose traction. That sure beats leaving your biggest 2wd tractor in the barn so you can pull out the smaller one when you get it stuck. Having that loader on dont hurt you with 4wd but is about the dumbest thing you can do with a 2wd because of all the fuel you waste pushing that dead, weighted-down front axle. Stick with your old 2wd's if you want to but trust me, you dont know what you are missing. I still have a few old 2wd tractors but they are pretty much reserved for summer use when all the spring mud holes are dried up completely, or winter when the ground is good and frozen. Give me my 4wd for the other 8 months of the year.
/ Tractor Pull!! #37
I've been stuck several times, 4X4 and 2 wheel drive, if you are stuck with a farm tractor the damage you did to the field is far more important than the tractor being stuck. 4X4 is quite important for farm type work but not so for pulling, where the rears are your bread and butter. I never really did any pulling but 4X4 does help with not getting stuck, its just like anything, in the right hands it is very handy, but if the 4X4 is not conected to a brain it helps you get stuck worse, so I guess you are both right. I always liked the tractor pulls where all these souped up pulling tractors huff and puff to pull a sled a couple hundred feet and then a farm tractor hooks on and pulls it back, all in a days work. HEE HEE!!!
/ Tractor Pull!! #38
I discovered the best tractor in a wet area is a great big one ... pulling a tile plow. ;)
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
4021 (A59228)
4021 (A59228)
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
VAN'S 300 GALLON-50' SPRAYER (A62130)
VAN'S 300...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
