Chain Question?
/ Chain Question? #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hi everyone,
I posted this question in another forum but no response yet. Maybe I was not clear.
I just purchased a new 2008 4320 with a 400x loader and HD bucket. I am going to weld on some chain hooks and would like to know what kind of chain to buy for pulling and lifting. What size chain and what grade do I need for a tractor with that HP? :confused:
Thanks
Dave
/ Chain Question? #2
Grade 70 5/16" should be plenty sufficient for anything you are going to do. I use 5/16" grade 70 for everything with my 50 hp Kubota and that has a lift of 3300 lbs, never broken one yet.
If your real nervous, 3/8" grade 70 is overkill, I have a bunch I use if the 5/16" isn't handy, just bulkier and not necessary.
The key is grade 70 or 80, do not go any lighter in grade, you will break anything smaller. We used to have a 1/4" grade 100 chain on the farm. Handiest chain we ever had. Couldn't break it, but expensive to buy grade 100.
/ Chain Question?
Thanks,
That's the kind of info I needed. :D
Dave
/ Chain Question? #5
You can buy these at Lowes, Home Depot and Tractor Supply in grade 70 for about $30 to $40 bucks.
Steve
/ Chain Question? #6
grade 70 5/16'' chain at tractor supply here is $4.00 a foot,plus the hooks are another five bucks apiece. sounds like he did ok.
/ Chain Question? #7
Just to add to the great info you already received, AW Direct has great hooks for welding onto your bucket.
/ Chain Question?
Steve
My Tractor Supply wanted $64 for just 20 feet of grade 70 chain no hooks.
/ Chain Question? #10
A couple years ago I found 30-40 feet of 1/2" G43 chain with slip hooks laying in the middle of the highway. Reading this thread and checking specs 1/2" G43 9,200 lbs work limit, 27,600 lbs breaking strength. G70 3/8" chain has 6,600 lbs work limit and a 26,400 lbs. breaking stringth. G70 is some tough chain.
/ Chain Question? #11
Lowes has 20' of chain with grab hooks each end for $35 made by Campbell.
I have used these for the last four years to tiedown my 110tlb. This is 5/16" with a 4700 lb work load and grade 7 (70 towing) .
Steve
/ Chain Question? #12
/ Chain Question? #14
Worked at place one time that was scrapping double decker car hauling trailers. The tie down chains were about 5' long with a grab hook already on. Wish I had got more than the four that I did......Great for final hook-ups when hauling logs, etc
/ Chain Question? #15
Needed to go to Lowe's today and have been reading up on bucket hooks and chains. Have about decided to go with three of the 5/16" hooks and pick up a couple of the Grade70 5/16" chains to go with it. Figure I could use them to tie down the tractor and for use with the FEL. I didn't see any bucket hooks, didn't check on the binders, but am attaching what I found on the chain. Took it out of the velcro closed plastic bag to make sure, but the chain is 20' long and comes with a grab hook on each end. Pulled up the TarpStop site and can not get them shipped from there to me for less than the Lowe's price.
1996 Sunflower 1543-38 Folding Disk (A63118)
1996 Sunflower...
2009 KENWORTH T6 SERIES (INOPERABLE) (A63569)
2009 KENWORTH T6...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2011 CLARK OIL FIELD FLOAT (A63569)
2011 CLARK OIL...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
