If you could what would you change
/ If you could what would you change #41
On my BX I'd like real oil pressure, water temperature, and voltmeter gauges like the old Steward Warner type. I would also like a relative height indicator on the mower deck. I have several locations in my yard where I would like to raise the cutting height about an inch or so and it's difficult to judge. My old 1572 Cub Cadet has a height indicator that works great. I second the parking break indicator.
kj
/ If you could what would you change #42
Some indication that the brake is set (light or beeper) so I don't drive away with the brake set. Also the tilt steering wheel lock lever (on B3030) mounted a little higher up so I don't unintentionally hit it with my foot during operation.
Absolutely right about the parking brake. Brake set indicator would be nice.
/ If you could what would you change #44
built in seat warmer
We don't need no stinkin' seat warmers here, but I can understand them for up north.
Here, we could use a lighter colored seat. Black is just too hot, especially with shorts.
Yellow wouldn't be right... maybe a very light orange.
Oh, and rear view mirrors.
/ If you could what would you change #45
Some great ideas! I'd like a waterproof tool box, some way to bring tools and a weedwhacker without using the FEL, and a little tray or cubby on the dash for cell phones or misc, Stuff. Other than that, I'm good!
/ If you could what would you change #46
put hooks on the ROPS and you can place your weedwhacker on there :D. Put the hooks on an angle so it won't protrude out too much on the sides. Just remember it's on there while driving.
/ If you could what would you change #47
Amen on the park brake Indicator. I find myself forgetting to release the park brake at times. I am sure that is not good on the tractor.
/ If you could what would you change #48
Oh heck, let it protrude....and keep it running. Let it trim on the run :D
/ If you could what would you change #49
Reduce the pucker factor on the B3030 with the option to have the rear wheels at a wider stance.
And yes, vertical exhaust pipe.
Otherwise, a great machine.
/ If you could what would you change #50
Why the desire for a vertical exhaust? To me, after bending the vertical exhaust on my M4700 on low branches, I think the below engine exhaust is an improvement.
Ken
(INOP) 1998 FORD F-SERIES FLAT BED TRUCK (A59823)
(INOP) 1998 FORD...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2013 MACK CHU (PINNACLE) (A60736)
2013 MACK CHU...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
