If you could what would you change
   / If you could what would you change #71
That looks like a couple of plastic drums with a battery driven pump and filter...I'm guessing that there is a nozzle on the other side of the wall. Is that what it is? How do you fill the drums? What kind of pump do you recommend? I may make up something like that. But if Kubota marketing department ever reads things like this, my preference would be for the Kubota to have a pump built in so that it could simply sip fuel itself from any type of container. How hard is that?
rScotty
   / If you could what would you change #72
Add a loud alarm if you try to move the tractor with the brake on !!!
I was just thinking....don't most Kubotas come with a backup beeper? I know mine did until I asked the dealer to disconnect it. My suspicion is that listening to a backup beeper isn't too popular around the house and most are disconnected. But but could it be rewired as a parking brake alarm?
rScotty....having just driven off - again - with the brake on...
   / If you could what would you change #73
It is no longer the engineers that are designing tractors. It is the lawyers and the court systems.
To expand on that thought....Those things do slow a guy down, but a clever engineer can usually design around the legal limitations and still get a decent design done. The problem often comes down to cost. It can be sad to see a useful mechanical feature get the axe because some other necessity ate up too many bucks in the cost budget. One thing that is always surprising to me is just how inexpensive simple things can be. At the manufacturing design level I bet I could add a toolbox with mounting hardware and a waterproof lid for five bucks. Most of the changes we are talking about in this thread seem to be low dollar mods.
I hope Kubota is paying attention. We've come up with a lot of good ideas here that could be implemented for not much money.
rScotty
   / If you could what would you change #74
L2800 owner here.
A dipstick to check HST fluid level, rathter than the inspection port. I would also like to see a toolbox on the tractor. Finally, I just hate the switch that turns off the engine if you stand up on the tractor when the PTO is running.
Bill
   / If you could what would you change #75
Lots of good suggestions!
B3200 - great tractor but the little things always seem to make a big difference
- ditto on the parking brake indicator
- ditto on the pre-wired plugs for hooking up extra lights
- seat could be even better (have been spoiled by the one on the M)
- dust caps for hydraulic connections for FEL are already not staying on - seem too soft now and keep falling off
- slightly wider stance in the front - not a big deal
- pre-installed 5/16 chain hooks on the bucket at reinforced locations
- MMM rubber bumpers so deck doesn't bang metal to metal when coming up
- and lets not forget about the vibration on this model at certain RPM
- idle seems high but I guess that is emissions related
- integrated remote hydraulic levers similar to B3030
- different design on the FEL hood guard / grill - current setup blocks a lot of light
Nothing on the M7040 stands out other than it seems we just missed getting one of the newer ones that had a turbo...next time..;-)
   / If you could what would you change #76
I would like some palce to carry pulling chains other than the floor boards or the bucket!. Also I think all of the B models should come with a factory rear work light.
   / If you could what would you change #77
l3240
An insert that prevents the level indicator rod from squeaking like a dry bucket pin :eek: made from plastic or some other material!
Annoying as **** but not worth the time to make one.:eek:
A screen for in front of the hydraulic cooler like the one for the rad.:confused:
A lock for the top link so it will not adjust by itself:mad:
As mentioned before, a pull out handle or a crank type 3ph level adjuster:D
All in all, a great tractor with almost 300 hours on it now and I still enjoy any seat time.:)
   / If you could what would you change #78
None of my 4 Kubotas have ever had backup alarms.
My Deere skid steer does have one. I disconnected it (the dogs ignored it anyway) but soon after I got an error code on the system! The system is too smart :mad:
The skid steer does have a brake alarm and won't let you even try to move if the brake is on. And you can't release the brake unless the seatbelt is on.
   / If you could what would you change #79
Now there's one thing that the M59 has that I wouldn't change...and wish all the other tractors with loaders came with the same feature. I'm talking about the factory loader bucket having two big flat straps welded to the top edge that are parallel to the cutting edge of the bucket and labeled as so...They are easy to see while operating the tractor. Finally (after 40 years) I can confidently tell exactly what the bucket tilt is doing. Duh...What took me so long? It's so simple.....
Guess that the indicator rod would of told me about half of the same thing, but I remember now that I took it off the first day to shut up that rattling sound. Besides, it doesn't show bucket tilt down anyway because the indicator rod disappears into the tube.
rScotty
l3240
   / If you could what would you change #80
Some very good ideas so far. Personally I think this thread would be more helpful if it were broken down by tractor series. For example the fuzzy dice... Just not right on a B series without a cab! LOL They'd get all wet!
Like many of you this summer, I found myself looking for a place to store a pair of loppers, shoves... while mowing without the bucket on. The idea came into my head. (The CFO feels that nothing enters the mind of a teacher during the summer but I proved her wrong!) Why not cut a piece of 3-4 inch PVC pipe with a cap on one end and simply put a hole in the other end that matches the bolt on the ropes? The bottom end rests in the useless cup holder, and the top is attached to the unused ropes bolt. Lopper, and short straight tools fit fine. As I mow if a branch is to low I simply reach for the lopper and no more problem!
Hey Kubota do I get a kick back on this?
One more thing...
With all of the lip Kubota took on the seats on the BX why in Gods (or insert your deity here) name did you put that seat on the B2920 with a BH? Talk about improvements needed!!!!!!!
Enjoy whats left of your summer!
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
