If you could what would you change
   / If you could what would you change #81
Now there's one thing that the M59 has that I wouldn't change...and wish all the other tractors with loaders came with the same feature. I'm talking about the factory loader bucket having two big flat straps welded to the top edge that are parallel to the cutting edge of the bucket and labeled as so...They are easy to see while operating the tractor. Finally (after 40 years) I can confidently tell exactly what the bucket tilt is doing. Duh...What took me so long? It's so simple.....
Guess that the indicator rod would of told me about half of the same thing, but I remember now that I took it off the first day to shut up that rattling sound. Besides, it doesn't show bucket tilt down anyway because the indicator rod disappears into the tube.
rScotty
Those straps // to the cutting edge always work. The indicator rod only gives an accurate reading at ground level....and is fragile to boot. :(
larry
   / If you could what would you change #82
:mad:
rScotty
I agree with you - my B7800 had those same flat straps that were level with the bottom of the bucket. My L5740 has the rod :(:mad:
I guess I could fab a couple and install - then throw the rod away!!
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
John Deere 980 Field Cultivator (A59814)
John Deere 980...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
Informational Lot - Financing (A56436)
Informational Lot...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- DEMO UNIT (A56438)
Greenworks...
