john deer 425 pto problem
/ john deer 425 pto problem #1
wanna
Member
orleans county new york state
jd 1070
Hi guys i have a j.d. 425 when i engage the pto sw it blowes the 15 a fuse if i disconnect the pto selenoid at the rear of tractor all is good could it be a bad solenoid i rang out the wiers to check for a grouned wier this was allso ok ohmed out the solenoid it self and have 0.0 ohms acrossed it not sure what it should be thanks for any info Art
/ john deer 425 pto problem #2
Art,
While they are different tractors, I had a similar problem with my 332. I removed the rear PTO and disassembled it, and found out that the clutch was way out of adjustment. The field coil was actually rubbing and had bare wires on the surface of the coil. It would work sometimes and generally short out after it warmed up. So you could get good measurements on it even if the coil is damaged. I'd suggest taking it apart and looking around.
/ john deer 425 pto problem #3
A zero ohm reading is telling you you've got a direct short, which as you know, pops fuses.
I see a new solenoid in your future.
/ john deer 425 pto problem #4
The 425 has a plug for the optional rear pto that lays inside the bottom of the frame rail. I forget which side. Check to see if it is hanging down and rubbing on your drive shaft and shorting out. There should be a couple rosebuds that hold it in place out of the way. Mine popped out and allowed the wire to rub on the shaft.
It is a 2 wire plug, T shaped from the end I think.
2019 CATERPILLAR TH255C TELESCOPIC FORKLIFT (A65053)
2019 CATERPILLAR...
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
2000 Freightliner Classic XL T/A Sleeper Cab Truck Tractor (A66736)
2000 Freightliner...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2011 BRENNER TANK PUP TRAILER (A67714)
2011 BRENNER TANK...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
