Pat's Easy Change Pat's Quick Hitch - Bushings Required?
   / Pat's Quick Hitch - Bushings Required? #1
gumshu
JD 2025R TLB, Kubota L4802 and Can Am Defender HD7
A friend told me that Pat's Cat 1 model has too much play when the hooks are lifted up to connect with the standard 7/8" Cat 1 pins; not a tight fit. Has anyone experianced this? Are bushings required?
   / Pat's Quick Hitch - Bushings Required? #2
Not sure what your friends issue is......Pat's work fine as designed.
   / Pat's Quick Hitch - Bushings Required? #3
I wonder if he has some of the "imitation" Pat's Quick Hitch products that Pat is fighting to keep from ruining his good name...
David from jax
David from jax
No, he said he has Pats Cat 1, #102. He said the hooks have about an 1/8' to 3/16ths play around the attachment pins and is wondering if bushings are required to take up the slack. It's not a tight fit. How much play do you guys have betwwen the hooks and the lower implement pins? Should there be that much play?
   / Pat's Quick Hitch - Bushings Required? #5
I have the PEC system and haven't noticed any excessive play with the pins. I'll take a closer look at mine next chance I get. Just a thought but maybe your friend should measure his pins and make sure they are 7/8"??
Thanks Kebo. He's the only person I know with the PEC system. He just got them, but I haven't seen them. I'm still thinking of ordering. According to him, he has the 7/8 pins. How much free play do you have between the hooks and the pins.... 1/8 to 3/16th's?
   / Pat's Quick Hitch - Bushings Required? #7
They have to have some slop as there are no balls to allow for movement. Put em on and try em out. If they are wrong Pat will make it right.
   / Pat's Quick Hitch - Bushings Required? #8
I can't tell you exactly how much free play mine has at the moment because my tractor is about 60 miles from here. It'll be next weekend before I can really try to measure anything. I do know that the PEC fits fairly snug, but still has to be able to move freely to change side to side angles as the implement is raised/lowered. Kind of hard to describe, but the PEC doesn't have a pivot ball like your side links normally do. So, there has to some freeplay to allow for that movement.
Thanks Again Kebo
   / Pat's Quick Hitch - Bushings Required? #10
my cat #2 Pats have just over 1/8 th inch play with new pins. I just miced the pin at 1.125" and the hook has a 1.267 gap which leaves a .142 of slop for the pin. I would think thats normal clearance. My cat #2 Pats have been used three times and are for sale if anyone is interested.
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
2013 International DuraStar 4300 Altec L42A 42FT Bucket Truck (A55852)
2013 International...
UNUSED FUTURE WALK BEHIND POWER TROWELL (A52706)
UNUSED FUTURE WALK...
2015 Honda Accord Sedan (A53424)
2015 Honda Accord...
