Difference between CUT and UT
/ Difference between CUT and UT #1
mrlullabye
Member
Just curious is there really any specific difference between a Compact Utility Tractor and a Utility tractor.
I just bought the Farmtrac 360 DTC a 39 HP 4wd machine that by my measure is pretty large, but I think it is marketed as a CUT. With the tires full of water and the FEL mounted I would have to think it is pushing 4000 pounds and I have a hard time calling that a compact anything.
Just curious if there is a true definition.
/ Difference between CUT and UT #2
That definitely a Compact. A Utility has a much larger frame, tires and is usually a Category 2 hitch.
Andy
/ Difference between CUT and UT #3
Andy
Gotta (ever-so-slightly) disagree with part of that. (But not so much as to say you're wrong....) I've seen many a utility tractor with CAT I hitch. I happen to own 3 of 'em myself.
Not sure there is a true "line in the sand" that defines the difference between a utility tractor and a CUT. I suppose it's more to do with WHO uses it and WHAT they use it for.
/ Difference between CUT and UT #4
A utility tractor will have WAY longer service intervals than a CUT
If you back up a CUT to a UT and compare the size of the rear diff, you'll immediately see the difference.
There are some really high HP compacts (55+) and some pretty small hp UT's (I know i've seen at least 55, I'm sure there are smaller than that)
/ Difference between CUT and UT #5
I thought I read someplace that a CUT became an UT at around 35 to 40 horsepower (or maybe down a little)
brian
/ Difference between CUT and UT #6
The terminology goes back to the early 1970's when the then major tractor manufacturers introduced imported (Japanese) tractors that were then smaller in size (and horsepower) than the smallest domestically produced tractors which were right around 30 -35 hp. Since then the differences have become blurred to non-existent with imports reaching hp in the 70s and domestics below 30. So, let's just say that CUT was a polite way of saying import back then.
/ Difference between CUT and UT #7
If you can climb into the seat by putting your left foot directly on the floorboard, its a CUT.
If you need to put your left foot on a step and then your right foot on the floorboard, it's a UT.
Case in point--my UT, a 2008 Mahindra 5525 (54 hp engine)
/ Difference between CUT and UT #8
my m59 is 60 hp, uses a step, I still think of it as a CUT though. Always thought UT started in the 60hp range. But all of that is really just guessing on my part
/ Difference between CUT and UT #9
Good question with no clear answer.
Wikipedia states "A Compact Utility Tractor, also called a CUT is a smaller version of an agricultural tractor but designed primarily for landscaping and estate management type tasks rather than for planting and harvesting on a commercial scale. Typical CUTs range in from 20 to 50 horsepower."
There is no mention of Utility Tractors on Wikipedia.
The Massey Website breaks down the tractors into the following:
High Horsepower (100 - 275 HP)
Mid Range Tractors (95 - 115 HP)
Utility Tractors (38- 85 HP)
Compact Tractors (23- 60 HP)
Sub Compact Tractors (22.5 and 25 HP), and
Specialty Tractors (57- 88 HP)
There are so many differences and similaritys between all the tractors, I do not think one can classify the differences.
Ivan
/ Difference between CUT and UT #10
??? That Mahindra looks like a Compact to me. My Ford 2120 which I need a step to get on is also a Compact. My TN 75D with both a step and a serious climb to get on is a Utility.
From Mahindra's own website "Tractor Overview: A superior performing tractor at a great value - the 5525 is an economical, rugged, compact 2WD utility tractor that offers versatility and ergonomic comfort."
If you see this Mahindra web site you'll see Mahindra plays it kinda loose with it's verbage: What's a Compact Utility--- a Hybrid?
Farm tractors for Ag Farmers, Hobby Farmers - Sub Compact, Compact & Full Size 2WD & 4WD Utility Tractors
Just busting ya.. :D Andy
/ Difference between CUT and UT #11
I think its easier with individual lines. For example, with Kubotas, I'd say the UTs start with the M series. Interestingly, HST seems never to be an option with an UT - maybe one could divide it up that way. The UTs don't want the HP loss to the PTO...
/ Difference between CUT and UT #12
??? That Mahindra looks like a Compact to me. My Ford 2120 which I need a step to get on is also a Compact. Mu TN 75D with both a step and a serious climb to get on is a Utility.
Just sales yada yada. Mahindra doesn't want to scare away the CUT buyer, so they call the 5525 "compact". It ain't, at least not in my book.
/ Difference between CUT and UT #13
I thought CUT or UT referred to frame or chassis size, and less than 100 hp, with some 45-100 hp tractors being also considered Ag tractors.
The Kubota M and MX series are larger framed than the L series.
The Massey 1600s and 1500s are definitely smaller than the 400, 500, and 54xx series.
I will say the larger L series tractors (5030) and 1500s (1557, 1560) make me think UT. The clearest difference I've seen between tractors of similar dimensions that were sitting side-by-side, was the difference between a Kubota L5030 and MX5000. The 5030 was big, but the 5000 just looked heavier duty.
If I farmed, I definitely would have what I consider an Ag or UT.
That's just my 2 cents.
/ Difference between CUT and UT #14
I believe that is absolutely correct.;)
/ Difference between CUT and UT #15
Interesting thread. For years I have always considered a CUT to be 50 hp or less. After that you get in to UT or AG tractors. Now a days they are marketing CUTS with more than 50 hp so I guess the definition has gotten cloudy.
MarkV
/ Difference between CUT and UT #16
I personally believe that it is 100% marketing terminology. Each manufacturer makes the delineation for their product lines. For instance, Montana designates everything from their 2740 to their 3940 and the 4540 (all without a cab) as compacts. The 4340C up to the U5784C are designated as Utility tractors. They also have a T2334 and T2734 that are designated as "subcompacts" and then several other models that are not clearly slotted into a category other than having a C, R, I, or P series designation.
I guess the only thing that keeps the 4540 from being designated as "Utility" rather than "compact Utility" is the lack of a cab, and the 4340C's cab pushes it out of the "Compact" range. Either way, the line does seem rather arbitrary.
/ Difference between CUT and UT #17
I always considered the old 8N a utility tractor at 23 hp while we raked 5000 bales of hay a year with it for 50+ years. I think it has more to do with use than size, Farm and Agricultural tractors are utility tractors, and homeowner tractors are CUT when they never leave the yard and they sit in a heated garage all winter. All the HP you can afford can't make a Tractor a utility tractor. Utility means to USE.
/ Difference between CUT and UT #18
MarkV
I just don't see any tractor that only weighs 4000lbs as being a Utility. That's a pretty ligtht machine.
Andy
/ Difference between CUT and UT #19
BINGO!
/ Difference between CUT and UT #20
I always think of Utility and Ag tractors as being able to adjust the tire spacing to accomodate row crop farming with 76" - 80" tire centerline adjustments being the normal distance for the tires. Most CUT even on the widest tire spacing cant accomodate that wide of a stance.
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2022 CATERPILLAR 262D3 SKID STEER (A62129)
2022 CATERPILLAR...
2022 Bautista Welding and Custom 40ft. 10 Ton T/A Gooseneck Flatbed Trailer (A61573)
2022 Bautista...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
TAYLOR 24 BLADE OFFSET DISC HARROW (A63291)
TAYLOR 24 BLADE...
KBH 1600 Gallon Water Trailer (A64047)
KBH 1600 Gallon...
