trailer tie down recomendations
/ trailer tie down recomendations #1
Dale1995
Caribou,Maine
John Deere 2320
Hi guys I just purchased a big-Tex 60CH tandem trailer today to transport my John Deere 2320. Love the trailer but am wondering what I should use for tie down straps, or chains. I found some at a local auto supply house that have a 1000 working limit, but I believe are rated to 3000 lbs....would this be good enough? What are you guy using? Any suggestions? Thanks.
/ trailer tie down recomendations #2
Ya might want to SEARCH as this has been beat to death. Chains seem to be best for live loads like a tractor. Straps for dead loads like lumber.
/ trailer tie down recomendations #3
Kevin is right, there has been discussion on this topic. I'll tell you what I do, take it for what its worth!
I secure my Kubota 2620 (the same size tractor as yours) with a 5/16" Grade 70 chain and a ratchet binder at the rear. I put a shackle on the drawbar and run the chain through this. I can't find a place on the front to run a chain without scratching paint, so I use two 10,00lb car hauler straps attaching to the lower box of the frame. These straps wrap around the frame and hook to themselves. They have a protective sleeve where they contact the tractor frame.
I'm not claiming this is the best way, but it's my way!
Will
/ trailer tie down recomendations #4
According to the fellow that sold the trailer to me, to satisfy DOT requirements, 4 chains and 4 ratchet binders attached to the tractor frame or axles are required. He has spent 40+ years dealing with DOT in the transportation business so, I would say that he knows what he says. I use the 5/16" G70 chain.
The FEL and BH, if applicable, need to be restrained, seperately.
/ trailer tie down recomendations #5
Hi guys I just purchased a big-Tex 60CH tandem trailer today to transport my John Deere 2320. Love the trailer but am wondering what I should use for tie down straps, or chains. I found some at a local auto supply house that have a 1000 working limit, but *I believe are rated to 3000 lbs....would this be good enough? What are you guy using? Any suggestions? Thanks.
*I think you need moore than shoe strings to tie it down.
Does it have brakes on 4 wheels?
How long is it?
What is your tow vehicle?
/ trailer tie down recomendations #7
Buy from a "proper" trucking supplier like below. You can get the right stuff ftom TSC but it is 3-4x the price. You want grade 70 chain and I got the 3/8" binders. I got 2 of the longest chains (24ft ?) with the hook at either end. With the ratcheting binders this is a very flexible system that has fit every move I have done so far. If you get short chains, you will be wishing for a longer chain by the second move or when you find you need to drag a log or pull someone out a ditch...
On the highways, law enforcement can and will pull you over for an inspection and if you don't have stuff rated for the job it will be a fine and you will get a tow from the operator that the sherrif calls.. Seen it happen a few times now.
Chain Binders, Load Binders, Ratchet Binders, Grade 70 Chain
/ trailer tie down recomendations #8
You don't need chains. :rolleyes:
My gosh, some of you guys are so **** about stuff it's a wonder you can transport a log splitter without a diesel DRW truck. :D We're talking about a subcompact tractor here, not a D-9. :D
Dale, take it from me an experienced operator that transports a 19,500 lb New Holland backhoe, there's nothing wrong with well made ratcheting straps that meet or exceed the WLL needed to hold your tractor in place. I do use chains & binders because of the weight, but I use straps on smaller tractors all the time.
These guys will have you buying battleship chains for a backhoe. It's overkill. Straps are nice because they are easier on your equipment and lighter/easier to operate. Get yourself some nice straps and enjoy transporting your machine.
/ trailer tie down recomendations #9
If the vehicle does not have proper eyes for securing it from the factory, then by all means use proper rated lifting slings. A 5000# rated sling is just $15. Even a small CUT weighs 1500lbs and can be lethal if it works loose.
Good equipment is like insurance. Spending $250 to get rated equipment for securing your tractor is peanuts compared to what it cost to buy the tractor in the first place. Compare that to how much you will be sued by the family of the person who crashed into your tractor after if fell off the trailer. Static loads like dimensional lumber or firewood are one thing, but a wheeled load is much more likely to move when stressed by braking or cornering loads. Chains have little give, which is a good thing. Straps by comparison have a lot of stretch and it can be shocking to see how a load "re-arranges" itself when using them.
How cavalier you approach the move also depende on whether you are going 2 miles, 10 or 200. Or over the rockies. Be safe out there..
Polyester Round Eye & Eye Lifting Sling 4' Purple Lifting Sling [PRS1EE-4] - $15.63 : Ratchet Straps, Tie Down Straps, E Track Tie Downs, Moving Blankets & Pads, Cargo Straps, U.S. Cargo Control
/ trailer tie down recomendations #10
This time I have to agree with Builder. I use my 4 2" x 8' long ratchet straps and 4 axle straps for 95% of the loads I carry, including my 5,200# tractor, dads Corvette, and numerous other vehicles as large as a Suburban. The straps are rated at 10,000# each with a WLL of 3,333# each. I do have 4 3/8" x 14' pieces of chain and binders but only use them when transporting something that my cut or rub my straps. By the way I also have 4 2" x 20' ratchet straps and 8 corner protectors for hauling things like lumber.
Chris
/ trailer tie down recomendations #14
Just remember that guys who possibly recommend incorrect and undersized tie down materials will in no way be in trouble if you take their recommendations and you lose your tractor, or worse. I hear the argument all the time that the cheapo $20 ratcheting straps will be fine 99% of the time. Taking their word for that percentage, let me ask you a question; do you wear your seat belt in in your car? Does your vehicle have airbags?
If you answer "yes" to either of those questions, you have already answered the question as to whether you are the sort of person who should use proper tie downs for your tractor. It's a well established fact that well over 99.99% of the time you get in your vehicle you won't need your seat belt. My guess is that you likely do wear seat belts and have a vehicle with airbags just for situations that aren't 'normal'. You know, like when somebody happens to pull out right in front of you. That's not supposed to happen, but I'd bet it has.
If you spent your hard earned money on a nice tractor, why would you want to get "cheap" and try to save an extra $75 or so to 'not wear your seat belt', so to speak? As many know, I had two of the straps that say "10,000 pound rating" all over them snap while going down a highway in a straight line. In my case it was just a dip in the road that caused my trailer to flex and, when the trailer flexed back, it snapped both straps holding the front of my tractor onto my trailer. Neither strap was across anything. They just snapped in half. I was foolish enough to take the advice of people who would in no way be responsible for what happened for their poor advice and nearly paid dearly for the mistake.
Take one of those cheap 2" straps that say "10,000 pound rating" on them and try something. Attach one end around the bottom of a large tree and hook the other end securely to your drawbar on your tractor. Back up and give yourself about 4" of slack and then drop the hammer trying to take off and see if you can break that strap. My little Kubota RTV can. Try the same thing with a 5/16" grade 70 chain and see if there is a difference. ;)
As mentioned, some will disagree. I have no problem with that. There are some people who swear that seat belts are dangerous and will relay some story about somebody being "throwed clear" when a car flipped and say that wearing a seat belt would have killed that person. I'm sure that theory is correct since every form of motor racing (where there is a higher chance for an accident) adheres to the "throwed clear" theory. Good luck and be careful with that nice tractor and new trailer.
/ trailer tie down recomendations #15
Just remember that guys who possibly recommend incorrect and undersized tie down materials will in no way be in trouble if you take their recommendations and you lose your tractor, or worse. I hear the argument all the time that the cheapo $20 ratcheting straps will be fine 99% of the time. Taking their word for that percentage, let me ask you a question; do you wear your seat belt in in your car? Does your vehicle have airbags?.............................
Not trying to argue, but just to set the record straight, I don't think anybody in this thread, including myself or DiamondPilot, suggested the O/P buy "cheapo $20 ratcheting straps" straps. In fact, In my case in this thread, I suggested:
Along those same lines, we all have to remember that just because chain is made from steel, doesn't mean it isn't cheaply made chain. Most people can't tell or don't know how to tell 70 chain from chinese junk, they buy what's on sale at Harbor Fr____. Same with chain binders. They can fail, too. Go over a bump and an improperly folded binder handle can pop loose. I see them going down the highway every day loose or popped.
We have heavy pallets of shingles, steel beams, huge paralams and 2 ton window walls delivered by boom truck onto buildings for years and have never even seen straps fail.
Quality chain is stronger, but too many don't know how to properly chain things down. The O/P is trailering a tractor a little bigger than the average lawn tractor. In his case, well made, properly rated ratcheting straps are fine. Considering what chain will do to the paint on his tractor since it probably doesn't have chain loops, straps are probably beneficial.
If you're worried about the tractor rolling forward, install dunnage around the tires or buy a trailer with a 16" bulkhead.
/ trailer tie down recomendations #16
I'm pretty sure Drago would agree with me, but folks I would not suggest trying that. It would definately result in serious injury.:eek::eek:
However, if we took the scenario described above, but lets say we made the scenario more realisitc and add a binder, end hooks and angles of attachment, etc to the chain. After all, we don't just use a piece of chain to secure a machine, we use a chain and binder, hooks, etc..
Also, since the chain is describer as "70 chain", which is high strength, we should make the parameters equal and use a quality ratcheting strap, right? I think that would level the playing field.
I'd bet more people that do that experiment with slack in the chain will pop a binder or loose a hook than the other group that breaks the actual strap belt on a quality ratcheting strap.
I have had rental machines delivered to my jobsites by guys I've known for 20 years and have millions of miles under their belts of delivering equipment that use quality made straps and dunnage for smaller machines.
/ trailer tie down recomendations #17
I don't see why it would not matter.
Somehow that doesn,t surpise me LB . :rolleyes: . Thats the difference between posting helpfull Info , versus typing just to be typing & answering questions with questions .
Back to the Original topic . Straps may be fine . But I wouldn,t want to use them on any of My & especially others equipment . large size quality chains & boomers are the only way to go IMHO .
I,ve also allways padlocked the boomers so they would not come lose nor be tampered with in the places where you might want to stop for a break while transporting . The straps can be weakened with a few cuts or worn spots from overusage or just not knowing how to tie something down correctlly . Also with a pocket knife if someone has the mind to . :eek: . But I,m not a very trusting person. :D . Bob
/ trailer tie down recomendations #18
Yes, others can type until they are blue in the face and there isn't even a remote chance that I'm going to believe a single word if they advocate using straps over chains for securing tractors. The only time I actually got to spend some 'quality time' with a DOT cop (female, but definitely a type A personality), they told me that if your load isn't worth securing properly it's probably not worth having. If she stopped you hauling a tractor the only strap being used better be securing an implement. Otherwise, grade 70 chain of appropriate size on all four corners with either ratcheting or lever binders securing the rolling load. Although not required, she also suggested blocking both the front and rear wheels as well.
As I've said before, I was stupid before and got lucky for my stupidity. It takes it to a whole different level when you've been told by the huge majority of people to use chains and you opt to ignore them and use straps anyway and then have a problem. If you want to use "quality" straps with the proper rating, that's fine. Just be aware that you'll be spending about double what the appropriate sized setup in chain will cost you, especially over time when you have to constantly replace the straps if they are exposed to UV rays, dirt, grit etc.; basically, if they are used.
/ trailer tie down recomendations #19
Oh well.....if you do use ratchet straps for light-moderate loads like me, my subs and delivery companies I have done business with for the last 20 years, check these videos out from Mac's Straps.
The 3rd video is particularly useful. It shows some great pro tips on how to strap vehicles down to trailers.
Their straps are some quality built stuff.
Macs Custom Tie Downs - Professional grade tie-down systems for car, truck, motorcycle, boat, or airplane.
Chains for heavy equipment-yep, you bet. Straps for stuff in the 3-8K range with a nice paint job or no loops for chain!
/ trailer tie down recomendations #20
Absolutely right! Even quality straps and strap ratchets deteriorate MUCH more quickly than chain. I'll stay with chain for primary tie downs. ;)
2013 CHEVROLET CAPRICE POLICE CAR (A66091)
2013 CHEVROLET...
2013 Ford F-150 Ext. Cab Pickup Truck (A66736)
2013 Ford F-150...
2017 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A69167)
2017 FREIGHTLINER...
2010 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2010 CHANDLER TRI...
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
2022 Ford F-150 4x4 Crew Cab Pickup Truck (A66736)
2022 Ford F-150...
