Kubota 1140 test drive
/ Kubota 1140 test drive #1
bosshoss
Just test drove a new 1140. Very nice liked hst trans and engine and tranfrormer bed seems more solid built than polaris ranger I tested at same dealer. Polaris tow and bed capacity much more, not sure why.
I am trying to find out if kubota front diff is open or limited slip. Dealer said limited slip but he acted like he wasn't sure. Anyone know for sure?
thanks in advance.
/ Kubota 1140 test drive #2
It is not a limited slip differential.
/ Kubota 1140 test drive #4
ATV RTV Whats's the difference.
/ Kubota 1140 test drive #5
/ Kubota 1140 test drive #7
I just have deja vous every time a read a post of yours.
Kyle
/ Kubota 1140 test drive #8
check his post count. you don't get to 13 thousand plus, without a little redundancy.:eek:
/ Kubota 1140 test drive #9
I think sometimes it would be nice if there wasn't a post count.
That way those who get all hung up over numbers would not get bent out of shape.
/ Kubota 1140 test drive #10
thanks in advance.
Don't get me wrong, I love Kubota....but check out the Kawasaki Mule 4010 trans 4x4 and compare it to the 1140 Kubota. You may find the cost of the Kubota is not worth it.
/ Kubota 1140 test drive #11
I was just busting your ///// a little bit. Nothing personal intended.
Post count, age, there are a lot of things which can influence one's impressions both positively and negatively. They're just data points. Be proud of your achievements. I'm 50 years old now. I'm proud to have made it this far, and accomplished some things along the way :D
/ Kubota 1140 test drive #12
Has anyone ever run 1 of these RTV 1100 or 1140 in say around -20 to -40 temperatures
we are looking at buying XUV 850D from JD or the RTV1100 and 1140 we know that up in Canada there are some oil and gas companies running the Gators with no problems in these temperatures but have not heard anyone talking about the RTV 1100 or RTV 1140 in use by any companies in oil and gas
/ Kubota 1140 test drive #14
Well, I have in -10F temps. Of course, you would be wise to use a 40W block heater and transmission heater of some kind in extreme subzero temps.
Are those oil and gas company Gators gas or diesel powered? Diesel engines can be more difficult to start in subzero temps.
2017 Mack Semi (A64047)
2017 Mack Semi...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61572)
2025 Mower King...
2017 TAKEUCHI TL12R2 SKID STEER (A64279)
2017 TAKEUCHI...
Patterson water pump (A59230)
Patterson water...
2022 CATERPILLAR 299D3 XE SKID STEER (A64279)
2022 CATERPILLAR...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
