PTO Shield extention?
/ PTO Shield extention? #1
CAB/AIR5225
marlow,ok
2011 John Deere 5065M
After installing my Imatch hitch, I hooked up my 6ft KK tiller. I didn't notice at the time, but after working the 3 point up and down a few times the inner shield came out of the outter...then when I went to lower the tiller..crunch. Now I have about 2 inches of damaged shield on both sides. What now? Anyone know if KK makes an extention?
/ PTO Shield extention? #2
Are you sure that the drive has enough overlap????
Well....the Imatch made about a 4 inch more reach for the shaft. I pulled them apart, and have about 3 1/2 inches of overlap....that may not be enough. I need the front part of the shaft that is about 4 to 6 inches longer.
/ PTO Shield extention? #4
I think you pretty much need a new driveline. Both ends should be of equal length. The old one was marginal at 7" lap. I think most are supposed to be 6" minimum. The shields are often a bit shorter than the shafts.
/ PTO Shield extention? #5
I bought a pto extension for my finish mower to work with my quick hitch on the tractor. The factory pto shaft was just a little short. I put mine on the mower gear box. Fit right on. You could also put it on the tractor side if you have multiple pto shafts that are too short.
PTO ADAPTER 1-3/8X6SPL M. X 1-3/8X6SPL F - Agri Supply
SWEET!! Thats what I need! Thanks Radman, ordering now.:)
/ PTO Shield extention? #7
Cab/air5225
If you plan on placing the extension on the mower side, be sure to check to see the diameter/style of the input shaft on the gear box. Many use the 6 spline x 1 3/8" version but yours may vary.
/ PTO Shield extention? #8
I think you will need a new diveline and the extension.. of the oem driveline was already onthe edge of being too short.. etc.
soundguy
Well....If the adaptor is giving 6 inches of extention, and the Imatch made 4 inches of extra reach for my driveline, sounds like I am gaining 2 inches??
/ PTO Shield extention? #10
If the adaptor is 6" long I doubt the extension will be much over 3"
Well....then I am within an inch of where I started before I got the Imatch...should work I would think....we will see.
20ft Shipping Container (A64047)
20ft Shipping...
43024 (A59228)
43024 (A59228)
Club Car Golf Cart (A64047)
Club Car Golf Cart...
2021 John Deere Z930M Zero Turn (A63116)
2021 John Deere...
2025 Polaris Ranger 1000 Side by Side (A64047)
2025 Polaris...
207277 (A52708)
207277 (A52708)
