3 pt carryall
/ 3 pt carryall #1
automech
SE PA
bx1500
What size/thickness angle iron would be good for a carryall that could lift 1000-1200 pound pallets? How long would the "forks" need to be? I want to order some metal this week, and I was thinking about 3x3x1/4" but I could go with 3/8 thickness maybe?
/ 3 pt carryall #2
I used 3x3x3/8" for mine... haven't bent it yet, but I don't use it for lifting pallets either. Are you going to put lumber on it and use it as a "carryall", or are you going to use it as a "forklift" for lifting pallets/round bales, etc.?
/ 3 pt carryall
Sorry for the long delay in replying as I have been pretty sick. I want to move pallets with firewood occasionally and some half or 1/3 pallets of landscape stone right now. After that, I will attach some planking or something to use it as a trailer of sorts. I have in mind filling it with downed branches an leaves, which I have an endless supply of, and dropping it at the burn pile or compost pit. I was kind of thinking of putting a big 3 sided bed of some sort just to move leaves. I wouldn't mind a towed dump type trailer of some sort but I think I will try the carryall because it is simple.
/ 3 pt carryall #4
3x3x1/4 has serious strength. Should carry 1200 Lbs no problem. Maybe weld a doubler where the hitch pin holes will be, if the threads are long enough. Just as much of the strength is in the design and construction as the material. A small strap here and there to prevent the angle from splaying out can make a big difference.
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
2021 Posi Track RT25 Compact Track Loader Skid Steer (A61572)
2021 Posi Track...
ROADTEC RX700 MILLING MACHINE (A64279)
ROADTEC RX700...
445 (A63290)
445 (A63290)
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
