Which size bush hog?
/ Which size bush hog? #1
firetractor
I was wondering with a John Deere 850...what is the correct size bushhog to use. 4' or 5'. Thanks for you help!
/ Which size bush hog? #2
You should be fine with a five foot bush hog.
/ Which size bush hog? #3
My brother in law has a 750 JD and pulls a 4 foot shredder clipping pastures in road gear with no stalling of motor. Pulls it in 1H in waist high grass and weeds so you should be able to pull a 5 foot or even a 6 foot with the 850.
/ Which size bush hog? #4
Good Mornin Gary,
I think a 6 ft rotary cutter would be a bit much for a 22 PTO HP tractor IMO. Unless its a very light duty mower just the weight alone is going to waggle that JD 850 all over the place. Throw in moderately high grasses or weeds and a slight hill and its all over ! JMO !
/ Which size bush hog? #5
IMHO.. 5' is the happy common ground for a rough cut mower... etc.
soundguy
/ Which size bush hog? #7
Until recently I owned a JD850, had it for about 10 years. Did alot of bushogging with it, a 5' will do just fine.
/ Which size bush hog? #9
The conservative rule of thumb I use is 5 pto HP per foot of cutter.
I pull a 6 ft with a 39 HP hydrostat and have NO difficulty whatsoever even in waist high or worse stuff. In really challenging situations I slow down some and still there is no problem.
I made a round trip to OKC today and the crews were out in force mowing the grass along the highways (Interstate 40 etc.) I was sort of surprised at how slowly they mow sometimes in what looks to be not especially challenging grass.
If I mowed as slow as they do I would be a longtime getting finished and I could pull a much larger mower than 6 ft.
/ Which size bush hog? #10
A rule of thumb is about 4 PTO hp per foot with a brush hog mower, some say 5hp per foot, it depends if you have slow speed gears to handle the heavy stuff. I have a 51" cut brush hog (55" width) with 16PTO hp and if the brush is too tall I can always drop down a gear, with the old fords N's 1st gear was too high speed is some cases to pull a 5ft. And they were close to 24 PTO HP. I have heard them taking 1/2 swath in heavy grass, ( 2 1/2 FT?)
2019 Ram 4500 4x4 S/A Dump Truck (A59230)
2019 Ram 4500 4x4...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
Case IH True-Tandem 330 Turbo (A60462)
Case IH...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2015 Ford F-250 Pickup Truck (A59230)
2015 Ford F-250...
2016 BOBCAT T740 SKID STEER (A62129)
2016 BOBCAT T740...
