Which size bush hog?
/ Which size bush hog? #1
firetractor
I was wondering with a John Deere 850...what is the correct size bushhog to use. 4' or 5'. Thanks for you help!
/ Which size bush hog? #2
You should be fine with a five foot bush hog.
/ Which size bush hog? #3
My brother in law has a 750 JD and pulls a 4 foot shredder clipping pastures in road gear with no stalling of motor. Pulls it in 1H in waist high grass and weeds so you should be able to pull a 5 foot or even a 6 foot with the 850.
/ Which size bush hog? #4
Good Mornin Gary,
I think a 6 ft rotary cutter would be a bit much for a 22 PTO HP tractor IMO. Unless its a very light duty mower just the weight alone is going to waggle that JD 850 all over the place. Throw in moderately high grasses or weeds and a slight hill and its all over ! JMO !
/ Which size bush hog? #5
IMHO.. 5' is the happy common ground for a rough cut mower... etc.
soundguy
/ Which size bush hog? #7
Until recently I owned a JD850, had it for about 10 years. Did alot of bushogging with it, a 5' will do just fine.
/ Which size bush hog? #9
The conservative rule of thumb I use is 5 pto HP per foot of cutter.
I pull a 6 ft with a 39 HP hydrostat and have NO difficulty whatsoever even in waist high or worse stuff. In really challenging situations I slow down some and still there is no problem.
I made a round trip to OKC today and the crews were out in force mowing the grass along the highways (Interstate 40 etc.) I was sort of surprised at how slowly they mow sometimes in what looks to be not especially challenging grass.
If I mowed as slow as they do I would be a longtime getting finished and I could pull a much larger mower than 6 ft.
/ Which size bush hog? #10
A rule of thumb is about 4 PTO hp per foot with a brush hog mower, some say 5hp per foot, it depends if you have slow speed gears to handle the heavy stuff. I have a 51" cut brush hog (55" width) with 16PTO hp and if the brush is too tall I can always drop down a gear, with the old fords N's 1st gear was too high speed is some cases to pull a 5ft. And they were close to 24 PTO HP. I have heard them taking 1/2 swath in heavy grass, ( 2 1/2 FT?)
/ Which size bush hog? #11
My Kubota 7510 has 17 or 18 horse pto and a 4' hog runs good until it gets to the thick 2' high alfalfa. Weeds are not a problem.
/ Which size bush hog? #12
I bough a used 5 foot field mower and have 27 PTO horses. In real heavy stuff I will drop it into low range, but it is rare I need to do that. I wish I had a 6 foot so I could clear the rear wheels making it easier to get close to fence lines and stuff.
I have a six foot flail and that needs the low range more often
/ Which size bush hog? #13
Good Evenin pat,
You gotta remember their trying to pick up some overtime ! ;) Mow slow and they will ask the crew to come in on saturday ! :)
/ Which size bush hog? #14
For the 850, I would definitely go with a 5ft BH. The 850's are rated for 24 engine hp, so it's about 21 PTO hp. I have owned two 750's (21 engine hp) and used a 4ft behind each of them and I think that was the right size BH for that tractor. I believe that if you got a 4ft BH for your 850, you would not be happy with it.
/ Which size bush hog? #15
Like others have said, a 5ft. would be fine.
/ Which size bush hog? #16
My family has run a 5' JD bush hog behind our 850 for 24+ years. Does great, no problems. If you have the axles spread wide, you will need the 5' width just to cover your tracks anyway.
Rod
Thanks everyone for all the help! I am new to compact tractors. I have a ford 4000 with 6' hog but it is too wide to mow between my pine tree rows, so that is why i purchased JD 850. Dealers say 5' "light duty" rotary mower but i wanted the opinion of those of you who are in the field using it. I noticed that the JD dealer sells frontier in light duty and those rascals are expensive...($1250). Is that normal...whew! What recommendations do you tractorites have. I dont want to be too cheap and get a mower that i am constantly working on or welding but would like to find a mower less expensive!
/ Which size bush hog? #18
Have you set the footprint in on the 4000?
soundguy
/ Which size bush hog? #19
You think that's bad, look at the price of a John Deere branded cutter! $6000 for an MX-8. See, that should make you feel better, :D:D:D
Actually that price is almost identical to the same level Bush Hog. I did find a Landpride a $1000 less, but carefully comparing the specs, it's not rated as strong as the JD and BH models.
Ten years ago, I got a medium duty 6' Woods. IIRC, it was around $1800.
I don't know how the Frontier line compares. There are "light duty" mower and then there are "very light duty" mowers. I'm sure you can find a cheaper price on a 5', but quality could be quite different.
Also, shop around at different dealers. I've found a $300 difference between different JD dealers on the MX-8.
Of course, you need to buy what's appropriate for YOUR needs. Maybe it's justified to spend more, maybe it's wise to buy an economy model.
Ken
Ken...you did make me feel better! I had purchased a king kutter for my 4000 5 years ago and have been working on it ever since. I really dont like my KK. I also found a cheaper 5 ' bushhog made by lowrey but you can tell the quality is not there. I shopped between JD dealers and one had a new 2008 model frontier that is $100 less so i am getting that one. I like the gearbox and safety chains on it. I just havent purchased farm implements in years so i had to get an IV for sticker shock!!!! Once i got the ringers lactate flowing while reading these posts i realized i had stepped into the big boys world! So it makes you hope the implements will last a lifetime! Thanks for your input. Sound guy....we toyed with the footprint thing but never could get what we needed. my trees were handplanted so that is going to create a challenge even with the JD 850....so big blue gets to sit this one out...but thanks for the advice.
(11) HAND SANITIZER STATIONS (A60736)
(11) HAND...
2001 Ford F-150 4x4 Pickup Truck (A61568)
2001 Ford F-150...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Root Rake Loader Attachment (A59228)
Root Rake Loader...
2025 Pabreak Hydraulic Vibratory Plate Compactor Skid Steer Attachment (A61567)
2025 Pabreak...
MODEL 14C SCRAPER (A58214)
MODEL 14C SCRAPER...
