Hydraulic pump to weed eater platform
/ Hydraulic pump to weed eater platform #21
Nitrogen is an interesting idea. Might have to design for shock prevention since a compressible flluid will tend to slam the jaw shut for example when the last part of the cut is a fracture. Also, I think that type of unit typically operates at 10,000psi so even at reduced load you wouldn't get much useful work out of a cylinder of N2. A better combination might be a CO2 cylinder powering an air/hydraulic pump.
I think a weedeater engine has plenty of horsepower - many times what that battery unit has. This can even be done with hand power. The OP's idea can certainly be made to work and it certainly lacks novely. It will be expensive compared to a single acting piston-powered-spring return deal. I imagine the 10,000psi gear pump will be as expensive as everything else combined. I actually have one on my junk shelf - too bad the OP doesn't deserve it.
Check out these offerings from you-know who:
- Harbor Freight Tools - Quality Tools at the Lowest Prices
Add a CO2 power kit from Lowes, a hose and a stick and Voila! A $300 porta-cutter on a stick!
Kobalt at Lowe's: Portable Compressed CO2 Regulator
Oh yeah, here are the formulas.
Force = Pressure *Area
Power = Force*distance/Time
For units go here:
Units of Measurement
/ Hydraulic pump to weed eater platform #22
What is 12 mm in inch's?
/ Hydraulic pump to weed eater platform #26
meaningless comparison without the specifics of both pieces of equipment
soundguy
/ Hydraulic pump to weed eater platform #27
I am looking for all the information I can gather form experts such as you as to the development of a design which I will describe. I have a need for a hydra operation that operates a scisser type mechanical device that will shear 1/2 inch bolts or 1/2 inch rebarr. This device would be best designed by attaching a hydra pump onto a weed eater and engine platform. Operations would be for a person to power the pump by running the engine which produces fluid power to a sisser mechanism located about 6 feet from the head/pump. One blade would be stationary and the other stroke operational. Of course an expandable coil hose assembly would couple the pump and scisser/shear. I would expect the shear to opeate with either a pull or push piston and a trigger switch would operate the function device. Though I am a BSEE I have very very limited knowledge of hyra and would appreciate all the design help you can support me with, even if it is send me to another site. Just pls give me some direction.
Needed to assemble a prototype unit:
1) Estimated hp for engine and pump.
2) Trigger/switch ideas.
3) Scisser mech piston or other operational device.
4) Fluid reservoir container and size.
5) Formula/s used to estimate the above.
The way hydraulic systems are designed is you take the work (how much required force you need), mate that with the appropriate sized cylinder(s). You may have to compromise between diameter and length because, the larger the diameter, more force is delivered. However, you may not have the space or room for a four foot diameter hydraulic cylinder.
Next you have to look at how much time you have to do the required work. This is where a smaller diameter cylinder comes in. It'll extend and contract faster than a larger diameter cylinder. However, a small diameter cylinder may not have the required force to do the job. Mate this information to the pump size. If you can afford to have a stationary pump, size isn't as much a consideration. If you have to carry the pump, you're not going to want to carry a 50lb pump. A large cylinder will do the work, but it'll take next to forever to do the work. Remember, hydraulics work on the principle of ratios. Small displacement pump and larger volume in the cylinder multiplies the power of the motor.
Now the pump. The rating on a pump is pretty much it. If the tag says the pump is rated at 2000rpm/5gpm, you're not going to get much more than 5gpm out of the pump by spinning it faster. Sure, you may get another half or so gallon per minute from the pump by increasing the speed by another 500-1000rpm, but that's really about it. You can flow only so much fluid through the ports.
I'll give you a tip; The manufacturers have handbooks that mate pumps with cylinder sizes to how much force you need. Figure how much force is needed to do the work you're envisioning and go from there. If I were you, I'd consider multiple links for leverage so I wouldn't have to carry the required weight of the hydraulics to do the work.
/ Hydraulic pump to weed eater platform #28
on a positive displacement pump.. output will be ratio tied to rpm.. however if you hav inlet or outlet restrictions, you will get cavitation or backpressures issues.
soundguy
/ Hydraulic pump to weed eater platform #29
Well heck, 1cm. = 10mm.:D
You still did not answer my question, and please don't answer or reference any of my post. :mad:
I am seriously thinking of adding you to my ignore list. :mad:
/ Hydraulic pump to weed eater platform #30
63DH8,
How large do you think that rebar cutter is from HF. It uses 10,000 psi, and that can be obtained from just about any hand pump, or one of the air motor driven hydraulic pumps. That is probably a carbide head on there, and cutter is rated at 12 mm, or.47 in, a little smaller than 1/2 in. If this were mounted on a solid line capable of 10,000 psi he could reach to whatever distance he wanted. If he is dead set on a weed eater engine, I just don't know. Probably the nitrogen would work. We still don't know the full extent of what he is trying to do. The rebar may be inside a pile of cement/rebar rubble. I have something that would cut just about anything, and that is the jet rods, or Exothermic/Slice rods. just need oxygen.
/ Hydraulic pump to weed eater platform #31
63DH8,
How large do you think that rebar cutter is from HF. It uses 10,000 psi, and that can be obtained from just about ant hand pump, or one of the air motor driven hydraulic pumps. That is probably a carbide head on there, and is rated at 12 mm, or.47 in, a little smaller than 1/2 in. If this were mounted on a solid line capable of 10,000 psi he could reach to whatever distance he wanted. If he is dead set on a weed eater engine, I just don't know. Probably the nitrogen would work. We still don't know the full extent of what he is trying to do. The rebar may be inside a pile of cement/rebar rubble. I have something that would cut just about anything, and that is the jet rods, or Exothermic/Slice rods. just need oxygen.
All true, but why give the man a fish when he could be taught to fish? ;) Besides, he said he's educated. BSEE and all. :D
/ Hydraulic pump to weed eater platform #32
In the manual for the HF cutter the stated capacity is actually 3/16 to 1/2" so it meets the OP requirement.
The HF unit can produce a maximum force of 8 tons at 14,500psi indicating a cylinder area of 1.1 square inches. Probably a good baseline for calculating power requirements. To go 1/2" in 1 second pushing 16,000lb requires about 1.21 horsepower. Let's say a total of 2HP is required due to friction. That number can be divided by the number of seconds allowed to accomplish the task. A typical weedeater is about 1hp so it should be able to make the cut in 2 seconds. If you allow 10 seconds, it only takes 0.2hp or 150 watts - pretty close to what a cordless tool can do.
I can't believe you guys got me to do this much of Mr. BS's work!
/ Hydraulic pump to weed eater platform #33
:)Think this out JJ. 1" = 2.54cm, 1cm = 10mm. Therefore 1"=25.4mm. Then 12mm = 12/25.4 inches = 0.472 inches......A little more than 15/32"
larry
/ Hydraulic pump to weed eater platform #34
Having been on a BUNCH of internet forums over the years, I can make a few guesses about the OP:
#1. English is not his native language, and I suspect he is not from in English speaking country.
#2. He has an idea for a product he thinks is the next "Big Thing". (Probably has watched too many episodes of Dragon's Den or Pitch Men)
#3 He has absolutely NO concept of the principles behind what he is trying to design, and thus wants US to do the work for him so he can then patent "his" design.
I could, in very little time, put together a working design for exactly what he wants, but knowing my luck Billy Mays would decide it's a really great product for him to scream about and my work would make some schmuck who was too lazy to learn to design things on his own a quick buck and I'd still be sitting here oblivious.
It's incredibly rude to come on a forum, make demands and then call the people who tried to help you fools because you don't have enough comprehension of your own topic to realize they were being serious. Being rude may get things done wherever you come from, but where, I come from it just makes people mad. (And yes, I am a bit angry after reading the first two posts. It just doesn't sit well with me.)
/ Hydraulic pump to weed eater platform #35
I think you can safely drop the EE in his "degree". He quite obviously has a degree in BS though. :D (Either that or somebody has resurrected Rube Goldberg)
/ Hydraulic pump to weed eater platform #37
I reccomend it...It's one of the most stress relieving things I've done lately :)
soundguy
/ Hydraulic pump to weed eater platform #38
I dunno. It kinda fits. Degreed in BSEE=Degreed in Bovine Scatology and Equine Excrementology!
/ Hydraulic pump to weed eater platform #39
larry
Thanks Larry. I just don't work with mm or metric system and all I wanted was a simple answer like [ 12 mm is .47 in ] So I did what I should have in the first place when I don't have an answer. I get on the Internet, and find conversion tables. I post about things that I know, or what someone wants to know, and try not to leave one guessing.
/ Hydraulic pump to weed eater platform #40
I have an easy way I keep them in my head. 1/2 inch wrench is very close to a 13mm wrench. So, that makes 1 inch twice that, or 26mm. It's not exact at all, but it will get you in the ballpark.
May or may not work for you, but it helps me do quick conversions in my head. Linear associations like that are how I remember many things, particularly conversions and dates. It's actually easier for me to remember that someones birthday is 60 days after a particular date than it is to remember the actual date. Just how I do things.
2016 INTERNATIONAL 7400 TREATER TRUCK (A65643)
2016 INTERNATIONAL...
Lowe Quick Attach 1650 Classic Hydraulic Auger Drill & Bit (A66285)
Lowe Quick Attach...
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
Landhero Backpack Leaf Blower (A66408)
Landhero Backpack...
Wolverine Quick Attach 84" Snow Pusher (A66285)
Wolverine Quick...
2017 INTERNATIONAL 4300 4X2 S/A 26FT NON CDL BOX TRUCK (A67147)
2017 INTERNATIONAL...
