WHAT DID YOU DO TODAY ?
/ WHAT DID YOU DO TODAY ? #221
It was 94-deg. here today & i mowed 7 1/2 acres of grass, and i drank a 1/2 gallon of iced tea:D
My wife tried to shut me down because it was so hot today:p
After i cut grass i took a ride on my motorcycle.
I also bush hogged about 10 acres of grass today. But I drank about a gallon of ice tea. Oh yea I forgot I had the A/C running in the cab also:D.
Then I also went for a 2 hour motorcycle ride with a couple buddies. There is a big difference between the A/C and the breeze you get when riding the motorcycle:)
/ WHAT DID YOU DO TODAY ? #222
I love to drink iced tea, it just goes down so smooth.
I didn't have A/C, but i had a fan under my canopy blowing hot air on me:D
I like to take a ride on a motorcycle in the evening, but you have to be alert for the deer running out in the road.
Maybe if i complain about the heat, then my wife will buy me a cab with A/C:D
/ WHAT DID YOU DO TODAY ? #223
Took a nap and then mow the yard around 7:00PM.
/ WHAT DID YOU DO TODAY ? #224
Went to the Milam County Registered Boer Goat Auction and brought home a young buck and three young does to add to the herd.
/ WHAT DID YOU DO TODAY ? #225
Good Evening Scott,
That's pretty quick!
Could you do it quicker by saying LB..:D
Just joking.... How do you like that job ??
Good Mornin Bill,
Well thats probablly a bit of exageration on my part ! :eek:
When you go to the terminal to fill the truck with a 6" fill pipe thats unbelievably quick ! In a matter of seconds you have 500 gals in the tank !
The job is good but it may get a bit rough in the winter when working full time, but then I jsut need to make it to next april and more part time weeks ! :) So far so good, we will see ! ;)
/ WHAT DID YOU DO TODAY ? #227
Too wet to bale hay so started putting this winters firewood in the celler:D.
Tom in Vermont
/ WHAT DID YOU DO TODAY ? #228
Split firewood yesterday & today.... That was 4 trees and i still have 11 big trees on the ground.
I'm going to have to hire some help to get it all done, and i have 3 sheds to build to put the wood in.
/ WHAT DID YOU DO TODAY ? #230
Split firewood all day.
/ WHAT DID YOU DO TODAY ? #231
Woke up to rain again for the 4th day ....Started the day with good intentions servicing combines and balers but got p!22ed off with the rain and took my boy out for lunch then went and looked how we were going to get a write off semi from an auction........bought a case of beer on the way home this evening...**** rain..!
18 holes of golf at 6:45 AM, then worked in the garden til about 1:30PM. Picked zucchini, peas, broccoli, kohlrabi, and a couple banana peppers. Looks like all *32 tomato plants are blooming, but no tomatoes yet:(
Mark
We've only got 8 plants.
First time wev'e planted anything in over 20 or 30 years I'd bet.
/ WHAT DID YOU DO TODAY ? #234
First I pulled a couple stumps using my box blade and my fel. Then I made a ditch to help drain water off my fields into a new pond. Last but not least moved most of the dirt from the ditch up to the house where I filled in some low spots next to the foundation for better draining. I did this all in about 4 hours, this would have been two weekends pre tractor.
You need to find a job that pays by the hour :D
/ WHAT DID YOU DO TODAY ? #235
Talked over putting down tarps around a particularly well-filled persimmon tree to catch some of the ripe fruit without fighting the poison oak, ivy, etc. We should have took care of this issue some time back.
/ WHAT DID YOU DO TODAY ? #236
Went to work anoly to have the ring & pinion come out of the rubbish compactor. Spent the day calling some friends and looking for a used unit in a 518 skidder. Finished the day hauling sand with the scraper to build up some roads for the rain and hauling some sealing clay. Got home 22 miles from work and realized I lftmy phone on the track of the dozer when I was shoveling them out. I had to go all the way back, Just loaded my hyster forklift on the trailer to take to work and pull off the steel wheels and planetaries and then the chunk. dreading tomorrow at the moment lol.
A couple of neighbors helped me out this winter after I had a stroke .
I got the chance to return the favor by spreading 2 piles of manure for another neighbor on his garden with my BX23 today.
/ WHAT DID YOU DO TODAY ? #240
just got home from volunteering at a local food bank, you would be shocked at how many people need a little extra help these days.
2006 Mack CV713 Granite Truck, VIN # 1M2AG11C06M033754 (A65563)
2006 Mack CV713...
100 Gal L Fuel tank (A65643)
100 Gal L Fuel...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2007 VERMEER T755 COMMANDER III TRENCHER (A65643)
2007 VERMEER T755...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
