Your towing rigs and trailers
   / Your towing rigs and trailers #441
Trying to see by enlarged photo.....big openings in the lower front bumper indicative of diesel?
If it didn't have trailer I might be able to tell better because trailer looks like it's pulling the nose up.
   / Your towing rigs and trailers #443
It's know if you click on the photo, it enlarges it. However, I didn't know until now that you could click it again and enlarge it even more. That helped me see the openings in the lower front bumper.
   / Your towing rigs and trailers #444
2003 Kenworth T800 wide nose heavy haul with custom built 2007 Cozad Generation x 16 tire expando lowbed,permitted to pull a gross wt of 126,000lbs 90,000 lb tare also Traileze Hydraulic Flip tail 35ton for those tight spots.
Cat 550 hp, Hydraulic retarder,Jake Brake, 18spd, full lockers :D
   / Your towing rigs and trailers #445
I just can't wait for someone to ask if it would be OK to tow it with a (insert 1/2 ton pickup model here) since it has trailer brakes and his wife likes the styling of the truck and they won't be pulling it THAT far THAT often... and they have some Wal*Mart bungee cords for strapping their BX whatever down.
Pat
   / Your towing rigs and trailers #447
I think I am going to need a bigger truck! Pulls good when it's flat but the hills are a killer.
   / Your towing rigs and trailers #449
Looks like you're hauling close to 7000lbs, A heavy duty truck... 1 or 3/4 ton should work just fine. Yours looks like my rig and trailer setup. I'm using a gas 3/4 ton F250. Wish I had purchased the diesel. Heavy duty pick up trucks have heavy duty brakes and transmission cooling; great for hills.
   / Your towing rigs and trailers #450
A 1/2 ton would too only it would ride better, get better gas mileage and cost less. You don't need a heavy duty truck until your over 9-10k lbs with these newer trucks.
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2000 CATERPILLAR 320C EXCAVATOR (A52707)
2000 CATERPILLAR...
John Deere 3pt 2 Row Planter (A53317)
John Deere 3pt 2...
2015 Ford Fusion S Sedan (A54815)
2015 Ford Fusion S...
JLG 1255 Telehandler (A55315)
JLG 1255...
SCAN TO RECEIVE TEXT UPDATES (A57193)
SCAN TO RECEIVE...
