Your towing rigs and trailers
   / Your towing rigs and trailers #461
I don't post much, but check in often for inforamtion - thanks guys
Figured I'd add a few
Couple different trucks and trailers - Same tractor
Andy
Andy, that is quite a load on the Ram! :eek: How much weight is that roughly? Is that a 4500? I didn't even know you could get the 4500 in a quad cab long bed... Did you buy the cab-chassis and put the bed on? That's quite the truck, it even has a sunroof, Nice! :cool:
   / Your towing rigs and trailers #462
Thank you!! Excavator is roughly 7K - Tractor is right at 4.5K - Trailer is somewhere around 8K - So I was running down the road approx 18-19K. Truck is just a little 2500. I've had a considerable amount more weight on the trailer before, but I prefer to keep my load under 20K when I've got more than about 250miles to travel.
Andy
   / Your towing rigs and trailers #463
Wow, that looked like a 4 on the "2500" badge. That truck has a tow capacity of about 13,250lbs and you have 18-19k behind it! :eek:
Glad we don't drive the same roads...
   / Your towing rigs and trailers #464
Andy
:confused:
I'm suprised you haven't broken anything major on that truck hauling that much weight that far. I feel for your leaf springs.
   / Your towing rigs and trailers #465
Actually if you look at his pic the truck is sitting fairly level. The trailer looks to be carrying the full weight of the excavator along with a good portion of the tractor weight. Still more than should probably be hauled with a 3/4 ton.
I did look up the tow ratings and found it odd that Dodge did not list a different tow rating for a fifth wheel/gooseneck compared to conventional tow (bumper). Using an 05 as an example - Dodge only list the tow rating as 13,100 for cab and 4wd. My Ford F250 regular cab powerstroke on the other hand list two different ratings - one for conventional towing at 12,500 lbs and list 5th wheel towing at 15,900 lbs.
I can tell you that I've towed 10,000 lbs using a 20' bumper pull and have towed 15,000 lbs using a 24' gooseneck. There is absolutely no comparison. I sold the bumper and now only use a gooseneck.
jk
   / Your towing rigs and trailers #466
Just got the trailer that I ordered. A Load Trail 20 foot flat deck car hauler adapter for dual use with the tractor as well. 10,400 GVWR, 8 welded D rings, Smoke grey, spring assist rear ramps. I plan on changing the wheels to alloy, putting a winch and an equipment box on the trailer tongue. I'm also adding Reese Dual Cam weight distribution with sway control.
2007 Ford F150 FX4, 5.4, 3.73 gears.
   / Your towing rigs and trailers #467
My old 2003 6.0 Power Stroke and my wife's 2005 DuraMax.
   / Your towing rigs and trailers #468
My 2008 6.4 Power Stroke.
   / Your towing rigs and trailers #469
How's your '03 6.0 worked for you? Some have had problems but I haven't. I've got a cab/chassis flat bed F350 superduty. Looks like those Fords are carrying the mail!:D Was the "wimpy" load on the Chevy your intent?:eek::D
Jay
   / Your towing rigs and trailers #470
Nice trailer and truck. Love seeing them Fords!
Chris
2020 DRAGON ESP...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
UNUSED WOLVERINE CCT-11-148V CONCRETE CHUTER (A57193)
UNUSED WOLVERINE...
Club Car Utility Cart (A55853)
Club Car Utility...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2015 MACK ELITE...
