Finally Got One - PTO Question
/ Finally Got One - PTO Question #1
jerkyboy
Upstate NY
I finally purchased a BX1500; paid $7,250. It's got 441 hours, 48" mower, FEL, quick hitch and shaft, grill guard, wheel weights, and chains. Tractor is in excellent condition and was always garaged and serviced by our local Kubota dealer.
Here's my question, the prior owner never used the rear PTO.....so, last night I shift the PTO lever to rear PTO only to make sure it works, and it does. The problem is that I can't shift it out of that position. I did everything by the book but it doesn't seem to want to come out and I don't want to force it. Any ideas:confused::confused:
/ Finally Got One - PTO Question #2
Congrats on your new purchase...I've had the same problem with my BX23...Took a little pushing/pulling on the lever and a slight sound of gears but I finally got it to go back to my MM position...Stick with it and you'll get it.
Don
/ Finally Got One - PTO Question #3
since its a meshed gearing for pto, it can't be forcced. All you need to do is kinda engage and disengage the pto a little then try shifting out of rear to whatever you need. It takes a little finesse and patience. When Mine doesnt shift, i just stop what I am doing and pretend to engage the pto a little then off. it will shift out of rear no problem. Good luck.
/ Finally Got One - PTO Question #4
I know this is not the answer to your question but here is something I encounter. Sometimes I have a little trouble engaging the PTO (mid or rear)
I just move the tractor a little forward of reverse to move the gears. When it is really stubborn it takes two or three "moves" but it never fails to make the engagement smooth. I mean just drive forward or back about a foot or so and try again.
/ Finally Got One - PTO Question #5
What radioman says is what I do. Turn the PTO on for a brief second, when it has almost stopped turning, change it from PTO to mid PTO. It may grind a little.
Thanks for the all the input. I'll try engaging the pto and then stopping it...sounds like that'll work:D
/ Finally Got One - PTO Question #7
Congrats You will love the BX1500.
Back in the last of 2007 I bought 2 of them.
I shifted the PTO on and off and moved the PTO position lever just before the PTO disengaged....worked like a charm!!! Thanks a mil for tip:D
2023 BOBCAT T66R-SERIES SKID STEER (A62129)
2023 BOBCAT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
UNUSED PEANUT WAGON QUICK HITCH (A62131)
UNUSED PEANUT...
JOHN DEERE 6105E TRACTOR (A62130)
JOHN DEERE 6105E...
(2) 460/85R38 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R38...
2020 John Deere 1795 Planter (A63109)
2020 John Deere...
