Hydraulic pressure relief tool
/ Hydraulic pressure relief tool #1
BeauGeste
I assume everyone has had the problem: You drop the implement in October, trying to get the hydraulic hoses as neutral in pressure as possible, and then go to hook it back up on the hottest day in June or July. That's right, the fluid has expanded and the snap-connects are impossible to join.
I've relieved the pressure by holding the host, using a blunt rod, my 2# sledge, and giving it a whack. After wiping off the sprayed fluid (and, yes, I wrapped it all with a shop cloth as best I could), it usually works. But, sometimes, it is quite pressured and you cannot give it enough of a blow to get the pressure relieved.
I did a Google search on "hydraulic pressure relief tool" and find two patents for exactly what I want. I also find a couple of references to Waite's Tools in CO, but going to their Web site is less than useful.
Does anyone have a source for such a tool? It is just me and no shop. I have to do my work outdoors. A tool would be greatly appreciated...
/ Hydraulic pressure relief tool #3
This is about the best way to relieve the pressure on the implement without a doubt. Put a tee in the implement on the backside of the QD. Any time you want to hook up, just crack the valve a little, and you can hook up. Then close it off before you operate the implement. If you are having trouble with the pressure on the valve side, just cycle the valve several times.
https://www.surpluscenter.com/item.asp?UID=2009061319233554&item=9-7281-6&catname=hydraulic
You could also use a needle valve.
https://www.surpluscenter.com/item.asp?UID=2009061319233554&item=9-4313-A&catname=hydraulic
/ Hydraulic pressure relief tool #4
My "special tool" is a pair of wrenches that I use to loosen the most convenient fitting.
/ Hydraulic pressure relief tool #5
I'm a tractor newbie, so haven't encountered the problem yet, but having spent my entire adult life in machine shops as a tool and die maker, I can think of a number of simple solutions..
In principle, think of a flaring tool that many folks have in their toolbox.. Apply that principle to a slice of heavy wall box (square) tubing. A slot in one side to grab behing the fitting opposed by a tapped hole or nut welded on the opposite side. Get a brass bolt for the ram to apply pressure to the poppet on the fitting and you're done..
For those that have an arbor press in their garage, just a slotted plate to slide behind the fitting is needed.
I love being retired, but IO miss unlimited access to a fully equipped shop to fabricate my toys.. But, I just might make one up... just in case!
/ Hydraulic pressure relief tool #7
Look at easyrelieftool.com.au
Quality custom made relief tools really work.
/ Hydraulic pressure relief tool #8
Sounds like an advert, given your user name, so this would be the wrong place, there is a place for ads. Also, the price, even when converted to USD, is a bit steep! I'm using an old gear puller, with the center screw cushioned with an aluminum plug. Works perfectly. Ten bucks if I would have bought a new puller; as it was, it was laying about, as was the bit of aluminum.
/ Hydraulic pressure relief tool #9
Yes it is we go strait to the users.
We have been in the hydraulic industry for over 40 years and our aim is OH&S, cost saving and eco friendly tool.h,a hamer hamer and bar works as well
/ Hydraulic pressure relief tool #10
I mounted some old female quick couplers to the lid of a 5 gallon pail. When I take my grapple off, I connect both lines to the 5 gallon pail. Problem solved.
Hydraulic Breaker Excavator Attachment (A59228)
Hydraulic Breaker...
John Deere 5000-Series Loader Frames (A63116)
John Deere...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
2004 John Deere 4720 (A60462)
2004 John Deere...
ATS RT12R Mini Excavator (A64047)
ATS RT12R Mini...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A59911)
2001 FREIGHTLINER...
