Why No Quick Attach Bucket on BX's?
/ Why No Quick Attach Bucket on BX's? #1
robertm
Northern Illinois
Kubota BX2660
Why No Quick Attach Bucket on BX's? Or the B's for that matter? I see the Green Machines have quick attach fron loader buckets that come off in a snap. Why can't Kubota do that? I can't see it putting that much more weight on the FEL and decreasing the lift capacity by much. It sure would be nice to drop the bucket at grab some forks made for the machine instead of aftermarket ones. Is there an aftermarket set-up like this besides the BXpanded forks?
/ Why No Quick Attach Bucket on BX's? #2
The B has a quick attach bucket as we have been discussing for the past few months. It just isn't the skid steer quick attach bucket. On the B, don't know about BX, yet, 2 easy to remove pins at the bottom of bucket and the bucket drops off.
/ Why No Quick Attach Bucket on BX's? #3
I expect the bean counters said "no". Same reason the ROPS knobs are missing on all the B2x20s.
/ Why No Quick Attach Bucket on BX's? #9
That is a sweet system. I wonder how much is the quick attach plate ? I can see myself to modify the snow plow I have to it.
/ Why No Quick Attach Bucket on BX's? #10
I emailed that company to see if they are selling them so if I get a response back I'll let you guys know.
/ Why No Quick Attach Bucket on BX's? #11
Well no email back yet BUT....I just happened to be searching through craigslist and look what I found!
Kubota BX pallet forks
Kubota BX pallet forks - $650 (Hutchinson)
Reply to: sale-r3fcu-1184638102@craigslist.org [Errors when replying to ads?]
Date: 2009-05-22, 9:54PM CDT
This system is specifically developed for the Kubota BX series tractor with the LA243 loader. The system is designed to allow you first the ability to have actual pallet forks not something you clamp to the bucket. And second you will be able to switch from your bucket to your forks and back again in seconds.
The pallets forks are designed for this tractor to be light weight to reduce the affect on lifting capacity, but durable enough to handle the abuse.The fork carriage is constructed of 1/4 A36 steel plate for strength and weight savings.
The forks are a fabricated design constructed of 3/16 A36 steel plate, are 36 long and rated for 250lbs each. The forks are the key to the weight savings on this because of the fabricated design they weigh only 30lbs each verses the formed solid type which weigh 80lbs each.
The other main component to the system is the quick-tach plate. It pins onto the loader in place of the bucket. Then you install the supplied replacement pins into the pin holes of the bucket and that's all you need to do. No cutting your bucket apart and welding new parts on or altering your tractor in any way. The Quick-tach plate is constructed of 3/16 A36 plate which is formed and welded to create a very solid channel. The capture hooks are cut and made from 3/8" A36 plate. All the bushings are machined to match the OEM hardware so no special tools are needed for the conversion.
Whatエs also unique about this system is if you doesn't need the ability to go from the bucket to the forks in seconds you can purchase just the pallet forks and they will fit directly onto the loader in place of the bucket.
To see a video of this system in action go to this link on YouTube. YouTube - Kubota BX series Versa-Daptor / Quick-tach system.
Pricing on the system is $999.95.
To buy the pallet forks separately it is $650.0 for the set.
To buy the quick-Tach separately it is $450.0 for the unit.
Sale tax applied to sales within MN.
For any questions or inquires email me at ai2products@gmail.com .
Or call Tony at 320-234-8331.
* it's NOT ok to contact this poster with services or other commercial interests
/ Why No Quick Attach Bucket on BX's? #12
Hmm, no response's eh? Thought someone might be interested.
I'm thinking about the quick-tach setup. I've already got forks that I made for the buckets that go on real quick but I'd have to redesign them to use without a bucket now.
/ Why No Quick Attach Bucket on BX's? #13
I was just waiting on you to buy it and post pictures.:D
/ Why No Quick Attach Bucket on BX's? #15
Bingo..I emailed them months ago and got the prices..Not cheap
You emailed ATI and got a price from them? Last I heard they stopped offering it for the BX.
How much was it?
/ Why No Quick Attach Bucket on BX's? #16
How much was it?
I emailed them back in Dec / Jan..the forks alone were over 1K..The guy you posted is a good deal..I like the quick hitch.
/ Why No Quick Attach Bucket on BX's? #17
Here is my homemade FEL with QA.
Click link below for more pics.
/ Why No Quick Attach Bucket on BX's? #18
Scarlo, I like your setup but the big difference between your setup (similar to JD's setup) is that there are two rams for curling the bucket. Because the BX series has only the one center mount HD cylinder, there is no way around a fairly beefy adapter plate.
I like the setup from AI2, but I think I am going to add change my curling setup to match yours (with two cylinders for the curl)
For someone who is not ready for such major changes to their machine, the AI2 setup seems a no brainer .....
/ Why No Quick Attach Bucket on BX's? #19
I would think that by extending the bucket out that extra 6" would drastically cut down on the lift capacity. The lift capacity is only 500lbs and I would imagine almost everybody with a BX has easily maxed that out, but it is a good looking system. I like the first quickattach better, much cleaner setup, but much more work. It would be perfect if it was built to the specs of a mini skid steer then all sorts of attachments would be readily available.
/ Why No Quick Attach Bucket on BX's? #20
I think the mini skid steer quick attach is the way to go. Look at the Toro Dingo and other walk behind skid steers. They have three cylindars and still have around 1000lb lifting capacity. The strength in the quick hitch can be done without adding lots of weight. Whenever I get the time and if possible a cheap mini skid steer attachment, I'm going to try to work this out. Hopefully it will come together.
2012 Kinze 3600 Planter (A63109)
2012 Kinze 3600...
2001 KUBOTA R520 BACKHOE (A62129)
2001 KUBOTA R520...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A62130)
2008 GMC C7500...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62131)
KNOW BEFORE YOU...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
UNUSED IRMC HIGH-END ELECTRIC MASSAGE CHAIR (A62131)
UNUSED IRMC...
