tc needs traction help
/ tc needs traction help #1
JWB53
07 toolcat
i mowed yesterday for the first time with my tc and 90 inch deck, mowing a lot in sandy damp soil, got stuck 5 times in about 5 hours, soil wasn't soaked just damp. any suggestions thanks, tc has standard tires (not turf) , mowing 6 to 12 inch grass, cutting height high as deck will go
/ tc needs traction help #2
What kind of tires on TC?
How high was the grass,and could you take less of cut until the ground dryer?
Do have pic/pics?
standard tires, (not turf) 6-12 inch grass, deck high as possible thanks
/ tc needs traction help #4
Was the TC stuck, like in mud, or just slipping on the surface due to wet grass? Or was it spinning in sandy soil? Hills?
When you were stuck did you check to see if all 4 wheels left spinning marks?
Some have said, the TC has better traction in 2 wheel rather than 4 wheel steering. I am not sure if I notice a difference. For mowing, it does much better in 4 wheel steer.
not wet grass just damp sandy soil beneath grass, does fine on dry hills, had 4 wheel spin marks , i was alone so i don't know if all wheels were spinning together or not, and tc was in 4 wheel steer, thanks
/ tc needs traction help #6
If you had spin marks from all 4 wheels, then it seems to be trying its best. I have posted many times that R4 tires don't have great traction in soft or muddy conditions. The TC's tires are not that big and your pushing over 6000 lbs of weight with the mower on. If the soil is sandy and the mower tires dig in a little, it is even harder to move.
I believe the TC's tires will allow 2:1 spinning on a D series. One tire may turn 2X for 1X of the opposite tire. This allows it to turn tightly without turf damage.
/ tc needs traction help #7
From experience with a heavy snow blower, some real ballast (like 500 to 800 lbs) in the rear bed helps a LOT! I use the solid 8x16x4" concrete blocks which weigh a little over 25lbs each set on a cut-down PU rubber bed mat.
As was mentioned above, R-4 tires are not ideal for the application either. Might also lower the tire pressure, but ballast weight will make a HUGE difference.
Good Luck
/ tc needs traction help #8
Don't believe these posts- you've got a drive system defect, or Bobcat has a false advertising problem.
What series do you have? Do happen to know the date of manufature or have your serial number handy? Are you very experieced with how a 4 wheel drive vehicle handles.
/ tc needs traction help #9
It sound as if something is amiss, causing resistance. You should not be having a problem.
Are you possibly placing too much downward pressure on your mower deck, driving the wheels into the soil?
Do your mower wheels rotate freely when you have it picked up? Sometimes they pick up grass and bind.
On a "C", a person is in 2-wheel drive when in 4-wheel steer or 2-wheel steer under normal operation. To get 4-wheel drive, it is necessary to first put the TC in 2-wheel steer, and then depress and hold down a button that engages 4 wheel drive.
If you are stuck with a mower, the best thing to do is detach the mower, try to get out without the additional weight. Then, once out, hook a chain from the lift arm to the mower, lift, and drag the mower to better ground to re-attach it, minding not to cut or tear out the hydraulic hoses in process.
Having a heavy ATV winch which you can plug into your rear receiver is great for getting un-stuck, and having a receiver you can put on the lift arm so the winch can also go in front is also great. With enough cable you can double the pull by using a pully which might come on the ATV winch.
While ballast is helpful when pushing down on a solid surface, it has the opposite effect when pushing on a soft surface. If you are stuck, the heavier you are, the faster you sink.
/ tc needs traction help #10
That's why I asked him what model he has- dollar to donuts it's a D, which apparently is so high-tech there isn't a button (and boy I wish there was!) to get it into four wheel drive.
o7 serial number a0w11660 , i have noticed all 4 wheels are spinning, i'm thinking the tire tread pattern and damp sandy soil combo give the toolcat trouble , it climbs great pushing the 90 inch mowing deck up hill if the soil is dry and not so sandy thank you
/ tc needs traction help #12
i have traction issues too using the brushcat in soft conditions. I have a late B series. I also have over 11000 hours in Bobcat skid steers. The standard tire is not very good in sandy conditions especially if you have them aired up to max pressure. I imagine the 90" deck is heavy. It sounds like there isn't enough weight in the machine and too much down pressure. If all 4 wheels are spinning, then you don't have enough surface contact.
/ tc needs traction help #13
With the bobcat mower, you can't have any down pressure. The mounting plate floats and the boom can be lowered completely and still not put any additional weight on the mower/wheels. The deck is heavy, and if the soil is sandy, the mower wheels may be sinking and giving traction problems. I have a D series with 90" mower and no traction issues but the soil is not sandy. The OP may do better by lifting the rear of the mower slightly and carry a little weight on the TC. Keeping the front tipped down will allow it to float over the terrrain. However, the cut may not be as good.
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60352)
2020 Freightliner...
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
HYUNDAI HLF25C11 (A60736)
HYUNDAI HLF25C11...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
John Deere Wheel Loader Forks (A60462)
John Deere Wheel...
