well-drilling with PTO??? anybody?
/ well-drilling with PTO??? anybody? #1
benjio
So i searched around and couldn't find anything... :confused:
Surely there must be a way to utilize the power and the PTO already on my BX 24 to help me drill my well, eh?
I have enough 3/4" steel pipe to get deep enough and an 8" bit. I've gotten down 10 feet by hand (right now the water table is about 2.5' below ground... so i shouldn't have to go too deep to get a nice supply), but there's gotta be a way to jury-rig some power onto that thing to spin it.
I'm not in any hurry, it's just for irrigation on my couple acres. I've already got a city water line comin in for the house.
Could I adapt a post-hole digger to turn the 3/4" pipe and still be able to send water down the pipe to the bit while it's drilling?
I've googled all over and seen a bunch of the home-job drill rigs, but I'd love to use the tractor for this if there's a good way.
thanks in adavance, k :D
Benji
/ well-drilling with PTO??? anybody? #2
I don't have an answer, but it's something I've thought about...
Why wouldn't it work?
/ well-drilling with PTO??? anybody? #3
My cousine bought a pto well driller on ebay, I can't remember the price, it worked til he hit rock. He broke a couple bits, got em stuck under ground, etc. Finally gave up and ended up hiring it done.
/ well-drilling with PTO??? anybody? #4
So for Hire is the way to go for my home site planning. However I will watch this thread that I may dig another well just for an additional sprinkler system for gardening.
/ well-drilling with PTO??? anybody? #5
I'm thinking a 3/4" pipe powered by a PHD is going to turn it into a pretzel! Lots of torque on relitively thin wall pipe driving an 8"auger!:eek:. Check this site for ideas:
Deep Rock Home
You could certainly adapt to drive it, but you'd have to have 3' section to keep adding on, plus, how do you get the cuttings back out of the hole? What's your projected final depth? ~Scotty
/ well-drilling with PTO??? anybody? #6
Benji, Your water table is not far down! Your can use a DrivePoint. They are made for that purpose. They are stainless steel I bought one from Sears years ago. If they no longer sell them someone does. Richard
/ well-drilling with PTO??? anybody? #7
I'm sure it is doable. That said, I know that 3/4" schedule 40 pipe will not handle the power necessary to drive a 8" drill for more than a couple of feet!!!!! If you were running that drill with 2" or larger, you might get 100' if you are lucky. If you did get 100' deep, think about how you are going to raise the drill and 5 sections of 2" pipe out of the hole?? Lots of weight. Not saying it can't be done, just not worth the effort for the savings. If it were me, I'd hire out the job and let them do the well caseing at the same time.
Chris
/ well-drilling with PTO??? anybody? #8
does your soil contain rocks or clay ?
We're on sandy soil, and have water jetted up to 10 meter with the manure tanker and a 2.5" pipe.
/ well-drilling with PTO??? anybody? #9
You are fighting an uphill battle.... best suggestion to date is a well point, stainless steel of course.... second best bet would be to install casing in the ten feet you have obtained thus far and then rent a high volume compressor with your 3/4" pipe set on bottom and blow out the well, which, in theory, will cause your existing casing to sink downward at which time you add another joint of casing... Visit your local well driller supply and obtain a polymer based drilling fluid, which, when mixed with water, will float the cutting out of the well.... Messy, messy work but depending on your geology, might.... might work.. Good luck.
/ well-drilling with PTO??? anybody? #10
Since you are in a SUPPER SECRET LOCATION it's hard to offer advice on your options.
The simplest way is to wash it down. I use 2" PVC, wash it down then drop 1 1/4" PVC with well point inside the 2" and then remove the 2" completely. I've done over a dozen wells this way, I have two on my property now. I've washed as far as 42'.
/ well-drilling with PTO??? anybody? #11
I have been trying to find someone who has used one of the portable drilling rigs. I would like to do my own well and I have at least two to do. I saw somewhere where there is a rig that works off the back of a tractor using the three point and hydraulics. My old brain cannot remember though.
/ well-drilling with PTO??? anybody? #12
A friend of mine built one many years ago using an old telescopic forklift rack to lower and raise a kelly swivel. He used a hysraulic motor to turn the pipe and a 2" pump with a 2000 gallon tank on a trailer. All of this was fairly involved though and not something I would try for financial savings. I sincerely think you would be money ahead to have it drilled by someone in the business.
If you wan't to do it yourself I agree with driving a point if the water table is close enough for you to reach.
Steve
/ well-drilling with PTO??? anybody? #13
I've talked to several commercial drillers and access is a problem... they all have large rigs and are unwilling to risk getting stuck on my back 40...
The other problem is they also get a big price around here.
I've looked at a few of the portable rigs and tried to rent one once... none of the rental yards have them anymore because they often came back damaged of broken...
/ well-drilling with PTO??? anybody? #15
Even if you were able to add sections of pipe to get as deep as you want to go, how will you get the dirt out of the hole since the auger is only 40 some inches long?
/ well-drilling with PTO??? anybody? #16
My well is a shallow well, I'm not sure how deep it is, but the pipe going into the casing is only 30ft. I use an above ground pump/pressure tank. Water seeps out between the top of the casing and the cap almost continuously. I had the water tested once, but still don't drink it.
/ well-drilling with PTO??? anybody? #17
they sell 2 inch and 1-1/2 inch driving coupling and make a bit for those electric jack hammers. I worked for an old coot that put in several wells a season this way. We would have the pipe cut and treaded to 5 foot section, buy driving couplings, get a sand point and a small gen set, stand on the tail gate or in the bucket and pound away.
went 40 feet in two hours, good luck
/ well-drilling with PTO??? anybody? #19
Depending how deep you have to go, seems like you could rig up something like this without too much effort. My water table is about 6-8 feet down and this is how I hope to put in an irrigation system later this year.
http://www.campbellmfg.com/brady/documents/wellinstallation.pdf
Seems very interesting. I have been wanting to put a system in for irrigation and was contemplating a well or using a holding talk and pumping in water from a lake behind the house. I thought i ruled out a well because i thought i cant do it without spending a lot of money for drilling. this looks like its worth a try. Holding tanks are a little pricey and not sure where/how to hide it. a 1500 gallon tank would be bit of an eye sore. Would like to burry most of it.
So i was reading the installation guide and it says to install one 4' well point per 1/4 pump. I am planing on irrigating around an acre and from what i have been reseaching i would need 20gpm at minimum and with a 1-1/2 pump. so i would need 6 points 5'-8' apart.
how about this, pretty much the same but with a video
Drill A Water Well In Your Backyard!
/ well-drilling with PTO??? anybody? #20
I saw this video and it your right, it is a similar concept ... the big difference is that the video uses an air powered "drill". Can you use a smaller HP pump and just have more zones?
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
24in pin on excavator tooth bucket (A61306)
24in pin on...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
2017 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A59230)
2017 GMC Sierra...
