tractor pricing vs engine size
/ tractor pricing vs engine size #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
In general you see a series of tractors with different model #'s same displacement,same weight but just different HP ratings.What are they doing to the non-turbo'ed engines to tweak the HP ? Changing injectors and pump settings? It would seem easier on the wallet to buy the lower HP tractor within a series and wait till the warranty is over and tractor paid for and then tweak the pump or change injectors to get the increased HP .Am I wrong ????
/ tractor pricing vs engine size #2
You might be right. I noticed this also when I was looking at Kubota M series machines. I actually made up a spreadsheet and charted the M series lineup in terms of tractor price/PTO HP. The price/PTO HP started at $574 for the M5040HD and decreased to a minimum of $416 for the M9540HD and then went up slightly with the M96S and M108S models. The M9540 was the best bang for the buck in both 2wd and 4wd models.
The M6040 and M7040 share the same engine, and the M8540 and M9540 share the same engine. Don't forget to consider other differences between the models besides engine HP. For example the 7040 includes a limited slip front differential and bigger wheels/tires.
As for myself, I bought the 8540 and it does all I need it to do. Like you I would be interested to know exactly what Kubota changed to get a few more HP in the 9540, but I doubt I would make any changes. If I needed more power I would probably trade up.
I want Kubota to offer a tractor I call the M9540V. This tractor would be a M9540 but it would have a computer system that would control certain parameters (fuel system, turbo, timing, valves, etc) to adjust the power over some range (perhaps 60 to 95 HP) as required/desired and it would improve economy and reduce emissions. It would also simplify tractor buying because it would reduce the number of models in the tractor lineup, which could perhaps lead to reduced costs. For example, the M5040/6040/7040 models could be replaced with the M7040V. The M8540/9540 models could be replaced with the M9540V. The M96S/108S could be replaced with the M108V...... What do you think?
I have been kicking tires for about 5 yrs now.I was all set on a JD 5205 with loader and an extra rear remote.But other financial things came up.But all the JD's in that range have the 2.4L engine (179ci).They range in HP from 48-77 HP , all tractors are the same weight,just different stock tire size and either turbo'ed or non-turbo'ed.Big difference in price too.So I do not think that pricing dollar per HP is a good way to get the most bang for YOUR buck,but it is a good way for the manufactuerer to make the most on a certain tractor by making you think you are getting alot more when you really aren't.
/ tractor pricing vs engine size #4
Kubota does what nearly every tractor manufacture does. Take the same engine, transmission and change the hp rating. In the small tractors it is usually the addition of a turbo or intercooler to get the different hp rating. In the mid and larger ag tractors, often the only difference is the computer module but the hp difference may 50-75 hp. Usually the injectors and fuel pumps are the same. These tractors will have the same part number for pistons, injectors, fuel pumps etc. The computer regulates the amount of fuel injected. The computers can be reprogrammed, but probably no dealer would do that. The manufactures want the exact serial number before any significant programming could be done to their chip. There are several aftermarket companies that have chips that can be used to change hp in the mid and large ag tractors by 10-35% depending on the desired setting and cost in the $500 range. Many of these devices plug right into the wiring harness. I don't know this for fact, but I believe they fool the computer into changing the hp by altering the fuel rail pressure reading. The computer reads a lower pressure reading and thus increases the pressure in the high pressure common fuel rail systems- which is basically what the manufactures does.
We have a Case-IH Magnum 245 (245hp). The tractor is identical to their 215 (215hp) and 275 (275hp) with the exception of a few features that are optional on the smaller sizes but standard on the large size. However, there are tens of thousands of dollars difference in the price. Dealers can discount the bigger tractor more than the same size smaller hp tractor due to the significant manufacture mark up on the large hp tractor, which is nearly the same tractor.
I am looking to stay away from turbo'ed engines since I plan on handing the tractor down to my son and want simplicity overall for longevity.I have a MF65 that I bought in 1983 and other than tires because of shale ripping sidewalls all I have done is a water pump,tune-up and fluid changes.
/ tractor pricing vs engine size #6
There's usually a little more to it then just turning up the wick on a fixed displacement engine. Higher horsepower means increased gas pressures and temperatures in the cylinders and higher loads on all the engine parts and the drive line. The heat loads are also increased so the cooling system and the oil systems(used for piston crown cooling as well as bearing lube) sizing is affected also. (By the way this also applies to turbocharged engines also.)
There are at least two rating philosophies: build the engine/driveline for the max rating and derate it for lower power, OR, add more robust components as you uprate the engine. The only way I know of to get an idea of what philosophy is being used is to look at the parts manual for the engine and driveline and see what parts change as the engine rating increases. if it's only fuel injectors and pump settings, then the first philosophy is being used . If there are lots of changes to components besides the injectors and the pumps settings then the second philosphy is in use.
Turning up the pump will generally shorten engine life and could effect the drive line life also. I my opinion, it's not good practice to do these things unless money is no object. You don't know where the weak link in the system is but you can be sure you will find it if you turn up the wick.
After reading JD specs on utility tractors I would have to say they build heavy then derate.The highest HP in class have turbo's then as HP goes down turbo's are removed,but displacement and engine model remain the same along with cooling specs being the same.
/ tractor pricing vs engine size #8
A turbo is nothing to be afraid of
/ tractor pricing vs engine size #9
Not quite true as there are different gear systems used in the drives on the different sizes mentioned.
I really love your thoughts that the price difference in the dealers hands!!!!!
Totally false-------- it's a flat line mark-up on every brand we sell!!!
Manufactuers do offer extra discounts from time to time for slow movers. They do this differently depending on the situation.
Some manufacturers trying to buy market share or get rid of old inventory will offer extended 0% sales beyond the other manufacturers time limits. They also will offer larger cash discounts on sales. It isn't a bad thing to watch for! On good brands it can happen at any time even in the middle of a program period.
Some brands that use the old tooling and older designs are cheaper to build by far often up to fifty and sixty percent or more. They often are machines that have the largest mark-up and are priced with-in five to ten percent on retail of the latest and greatest although when in the field they are often heavy and cumbersome to operate and you might think that exon is the importer. They look stronger do to the bulk mass but are often built using lower grade materials that are more porus and also subject to fail.
This is a interesting area that we are continually working with when trying to find the best value tractor for a customers work load.
/ tractor pricing vs engine size #10
Yea, lots of misinformation in this thread.
When you see the same block used across models, its never just an injector change or reprogrammed computer. These is more to the story than what your seeing on the spec sheets.
/ tractor pricing vs engine size #11
Messick, just wonder what your opinion is. Putting price aside, compare two of the same blocks with different HP, in the same size tractor, used for the same tasks. Is there an advange of going with the lower HP for longevity? That is, will the higher HP put more stress on the engine and cause a shorter engine life? And if it does, do you think the difference in life span between the low and high HP engine is significant?
Thanks.
/ tractor pricing vs engine size #12
I beg to differ. Check the part numbers. At least with Case-ih and JDs in the mid and large ag tractors, the part numbers throughout the tractor series will be nearly identical unless the engine has a different displacement. The only difference has to be the amount of fuel injected, which is likely only due to different pressure in the high pressure fuel rail system, fuel pump, injector or the turbo is different. The Case-IH magnum models 215, 245 and 275 vary by 60hp. The turbocharger, intercooler, fuel pump, block, crankshaft, piston and any other part I looked up have the same identical part number. The 275 uses a different injector, and has a 5 core radiator vs 4 core in the small tractors. Transmissions, wheel base, height, and hydraulic capacity are identical. The 275 uses a 12 bolt front end standard and the other 2 use 10 bolt, but can be optioned to 12 bolt (12 bolt is recommended for front duals and carrying tanks). 3 pt lift on the 275 is 14,970 lbs but the others can be optioned to the same or higher lift. The difference is cylinder size. The 275 costs thousands more than a similarly optioned 215 because of different injectors and slightly larger radiator and computer. One wouldn't think the injectors or radiator could cost that much.;)
/ tractor pricing vs engine size #13
Look carefully at the RPMs used to deliver the rated horsepower. At least for compact tractors, they either increase the displacement slightly, or they bump up the RPM to get a few extra hp.
The B3030 and B3200 use the same basic engine (V1505). The B3030 is 30 hp at 2600 rpm and the B3200 is 32 hp at 2700 rpm. And both the B2920 and my ZD331 use the D1305 engine. In the B2920 it's 29 hp at 2800 rpm, and in the ZD331 it's 31 hp at 3000 rpm. Yes, Kubota does make the engine numbers different in these applications (last 2 digits) to account for slight application differences. But unless you have forced induction, you can only increase horsepower by increasing displacement or engine speed.
Also note (as mentioned previously) that there are sometimes subtle differences besides the hp rating when moving up the line.
Guess I opened up a wasp nest on this one.
/ tractor pricing vs engine size #15
Milkie you did fine and it's not really a problem!
There are other things that get into it, like the size chassis that goes with the horsepower! Some models stay lighter, often giving a price point on the horsepower vs the weight.
Some are heavy on all chassis sizes, these are often older designs that were used by larger companies twenty to forty years ago and were discontinued by the original designers and later were purchased by another company and put back into use.
These are some of the more economical chasssis to buy as they are cheaper to build with the older cast being cheaper to buy then some of the newer nodular cast pieces being used which is some of the strongest cast being built in this industry.
There is a lot to tractors, the best to look at is what you need to do, then figure how long you want to do it and then start sizing the tractor, start looking for brands that are available in your area and then start the pricing. The best part, come back here and throw it around again!~
Well I was looking at the JD 5000 series back a couple of years.All across the board in the brochure cubic inch remained the same.Turbo-ing was the only difference and tire size on the 2 highest HP models.Weight was almost identical and probably would have been if they all had the same tires.It will be a hard sell to me to try and tell me those 4 tractors were all different even though there was a 30 HP spread.Coolant capacity even the same on the turbo'ed vs non-turbo'ed models.
/ tractor pricing vs engine size #17
the injectors are different on all the models you're speaking of, as well as the fuel pump. same parts, just different settings basically. from what i understand the turbo is the same size in all of them as well, just boost is different in all 4 models. so for instance, the turbo on the 5103 is the same size as the one on the 5403, just that the 5403 puts out more boost then the 5103 turbo. the 2.9 engine that's in this series of tractor is acctually rated for up to 85 engine hp and the 9x3 transmission is rated to hold up to 90hp. same entry level transmission you find on the 5000,5010,5020, and 5025 series tractors. do a search on here for a guy named TurkFlyer. he worked on this series when it first came out and his posts will answer 99% of your questions. that's where i got my information from, that and the mechanic at my dealership.
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
KMC 7406 (A64126)
KMC 7406 (A64126)
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2018 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2022 EZ-GO ELITE...
