Front Wheel Drive shaft BX2200
/ Front Wheel Drive shaft BX2200 #1
Skip G
Member
Cheshire, Oregon
Kubota BX2200
Anyone ever hear of the bracket that holds the bearing for the front wheel drive shaft failing ?
/ Front Wheel Drive shaft BX2200 #2
That sound like a rather odd failing. Do you use 4 wheel drive a lot? How many hours on the meter?
/ Front Wheel Drive shaft BX2200 #3
Haven't heard of that one, till today...Did it possibly get hit?
Don
/ Front Wheel Drive shaft BX2200 #4
That does sound like an odd failure. I did have the roll pin that holds the frond drive shaft break, allowing the shaft to fall off the spline at that bracket. I guess it is possible that if the front axle was pulling hard when the shaft came off of the splines that it could put a good bit of force on that bracket.
/ Front Wheel Drive shaft BX2200 #5
I just saw your picture on your other post. WOW!!! Was there any rust in the breaks? Any chance you hit it on something solid? Looks like it is time for a new bracket, although I would look into having it welded.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
48x4 Mini Skid Trencher (A61307)
48x4 Mini Skid...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
(APPROX. 20) 4' X...
2017 Ford F-250 (A55973)
2017 Ford F-250...
