add 3rd function to L3400
/ add 3rd function to L3400 #1
wildwillie
north Idaho
L3400,
I just bought a kubota L3400 and now want to add a 3rd function to the fel for a bucket grapel. Dealer wants $800.00, seems really high.I know it isnt hard. Any advice ?
/ add 3rd function to L3400 #2
Willie
I am taking delivery of my new L3400 today. Won't be doing the grapple right away but someday, so I will be watching your thread and progress. Keep us informed. What all was included for $800. If it is just a valve and a couple hoses I agree, sounds high. I have not checked if the loader valve is power beyond, will know tonight.
DRL
/ add 3rd function to L3400 #3
I have no idea what you have in mind for a design, but I'll offer that if you do it yourself you'll have maybe $500 in hard parts -- valve, fittings, hoses, brackets etc. Then there's your time --- so, is your time worth $300 to you?
The $800 is only for the installed dirverter valve and hoses Dosnt include transport to and from dealer. I dont have a trailor so I have the dealer come get it. Plus if I can save a couple hundred bucks, YOU BETCH YA. Plus I like to tinker,Is the valve the dealer will install the best, Ive heard stories of leaks ? Dont want to reinvent the wheel Just get the most bang for the buck.
/ add 3rd function to L3400 #5
I added a grapple control to my l3400. I went with electric over hydraulics.
I installed a marine switch on the dash.
I ordered the wrong valve because I ordered an open center valve. We have open center system, you need a tandem center valve
It uses a D03 base, here is the link.
Northman Fluid Power Hydraulic Directional Control Valve 19.8 GPM, 4500 PSI, 3-Position, Double Solenoid, Tandem Center Spool, 12 Volt DC Solenoids, Model# SWH-G03-C6-D12-10 | Power Solenoid | Northern Tool + Equipment
Here is a link to grapple project on a L3400.
http://www.tractorbynet.com/forums/attachments/134273-making-different-grapple-forks-bucket.html
I like your grapel knight, Northern calls for a d05 subplate maby i'm missing something?Whear did you pull supply & return from? I like the grapel being seperate from the bucket.
/ add 3rd function to L3400 #7
I pulled from the power beyond fitting to a loop at the back of tractor for backhoe,to my D03 Block, then it returns back to the main hydraulic block underneath the brake area, from there it feeds 3 point hitch internally in the tractor.
I don't have power beyond so I'll have to do some plumbing research. Still haven't found the do3 base. The picks really help, THANKS.
/ add 3rd function to L3400 #9
What type of FEL do you have? - I have a L4310 w/ a LA682 FEL and plan to add a 3rd function - elec over hydro...wondering how simulair our tractors are in regards to adding a 3rd function.
Thank's knight, I've got to pick up a repair manual. going to order parts,will post how it goes. FeLL is LA463.
/ add 3rd function to L3400 #12
WILLIE, you can buy a simple monoblock lever-actuated spool valve,
like the Prince unit from Northern. Don't forget the Power Beyond
sleeve, cuz your 3-PT is normally powered from the PB of the FEL
valve. You can install your new 3rd function valve between the FEL
and 3-PT. Cost will be $100 for the valve, plus a couple more hoses,
some fittings, and a mounting bracket. No need to spend $800.
Thanks for the info, I searched northern's site no luck finding anything on a power beyond sleeve,What does it do?
/ add 3rd function to L3400 #14
I used a electric diverter valve on my grapple cost 250.00 including fittings just plumb your tilt cylinders in and out again push button close open grapple release button tilt bucket normally
I've bought the dirverter valve and base, how do I run the return line ?
/ add 3rd function to L3400 #17
What return line? If you bought a solenoid-operated diverter, it prob has
two pressure inlets from your mechanical valve, and four outlets that
go to your cylinders, 2 to one, and 2 to the other. If your cylinders are
paired, then your diverter outlets get teed into each pair.
I just checked with NorthernTool and you are right that I do not see many
explicit listings for the power beyond sleeves for their Prince valves. A
buyer would probably have to ask to get them. You won't need a power
beyond setup since you are going to divert the flow from a work circuit
on an existing valve.
/ add 3rd function to L3400 #18
I added this an electric over hydraulic control to my M6800. WR Long sells the entire kit, set up specifically for each model tractor. Mine costs around $600 if I remember correctly. My dealer installed it but it would not be too hard to do it yourself. It did require a little welding to attach the quick connect bracket to the FEL. You can go to the WR Long website to see this. They were really nice to work with.
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
2014 Nissan Sentra Sedan (A64557)
2014 Nissan Sentra...
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
2019 Ford F-150 4x4 Pickup Truck (A64556)
2019 Ford F-150...
T/A Drop Deck Equipment Trailer (A64556)
T/A Drop Deck...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
