grease question
   / grease question #1
HVACDIESEL
What type and brand does everybody use.I am going to give my BX-24 some grease.
THANKS
   / grease question #2
THANKS
You might try to search this site using the term "grease". It will bring up many pages of info.
   / grease question
THANKS diesel power Some good reading
   / grease question #5
I use New Holland "Ambra" grease. I do a lot of greasing. In a day whatever is greased is going to get greased again at the end of the day. I think greasing often is more important than the type of grease.
   / grease question #6
If you have a loader of some sort grease type is also very important. You could run a continous grease pump setup and still have major wear if you don't use a Moly fortified grease in this type of application. Under extreme loads even the best grease can easily be pushed out of a pin and bushing on loaders. The Moly forms a solid lubrication film as a last defense against metal to metal contact. I have seen customers replacing loader pins and bushings 2 or 3 times a year that switched to a Moly fortified grease and had their pin/bushing replacement go down to once every 2 or 3 years.
   / grease question #7
Rotella.
   / grease question #8
Mystic with Moly for the FEL (I grease it after EVERY use); Mystic Red Grease for everything else. :p
Troy
   / grease question #9
Be sure to use the correct type of grease for your application, you would use 2 different kinds, say one for the mower deck hubs which would be a would offer high tempurture proctection for rotating equipment, versus a fitting on you FEL which would offer more shear load protection as Phyxer mentioned these would be moly based. Its also referenced in the OEM.
   / grease question
How about the factory Kubota grease? They offer 2 different types
1265 (A50490)
1265 (A50490)
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
