grease question
   / grease question #1
HVACDIESEL
What type and brand does everybody use.I am going to give my BX-24 some grease.
THANKS
   / grease question #2
THANKS
You might try to search this site using the term "grease". It will bring up many pages of info.
   / grease question
THANKS diesel power Some good reading
   / grease question #5
I use New Holland "Ambra" grease. I do a lot of greasing. In a day whatever is greased is going to get greased again at the end of the day. I think greasing often is more important than the type of grease.
   / grease question #6
If you have a loader of some sort grease type is also very important. You could run a continous grease pump setup and still have major wear if you don't use a Moly fortified grease in this type of application. Under extreme loads even the best grease can easily be pushed out of a pin and bushing on loaders. The Moly forms a solid lubrication film as a last defense against metal to metal contact. I have seen customers replacing loader pins and bushings 2 or 3 times a year that switched to a Moly fortified grease and had their pin/bushing replacement go down to once every 2 or 3 years.
   / grease question #7
Rotella.
   / grease question #8
Mystic with Moly for the FEL (I grease it after EVERY use); Mystic Red Grease for everything else. :p
Troy
   / grease question #9
Be sure to use the correct type of grease for your application, you would use 2 different kinds, say one for the mower deck hubs which would be a would offer high tempurture proctection for rotating equipment, versus a fitting on you FEL which would offer more shear load protection as Phyxer mentioned these would be moly based. Its also referenced in the OEM.
   / grease question
How about the factory Kubota grease? They offer 2 different types
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
HONDA EU2200 INVERTER (A50854)
HONDA EU2200...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
2016 CAT 289D SKIDSTEER (A50854)
2016 CAT 289D...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
