JAVA problems in IE7
   / JAVA problems in IE7 #12
I second that, less Micro$oft on one's computer is always better.
I wasn't implying IE was the problem, rather, trying the other browser to troubleshoot the problem. I use Firefox most of the time. However, there are some problems with it as well. For instance, some websites have not been designed to work with Firefox. Also, Firefox does not always play well with corporate security.
I did find a neat feature for Firefox where you can right click on a link and choose to open it in an IE tab. It uses the IE engine in the Firefox browser. That gets me around the few places where Firefox does not work correctly.
I'm still waiting to hear back from the foreman whether this fixed his problem or not.. I removed all java. plus some other junk he had installed, put in firefox ( works ok.. ) re downloaded java while his pop up blocker was disabled...
We do have to access a few websites that are IE only .. so will see where this goes... Am hoping this fixed his problem at least for now... will post back when i hear more.
soundguy
update... can't download java now :( download starts.. then hangs and never completes... Stuck now worse than before...
soundguy
   / JAVA problems in IE7 #15
   / JAVA problems in IE7 #16
soundguy
Are you attempting an install over the internet or a download? The reason I ask is that we have had trouble installing Java over the network. Instead, we download the files to the computer, then run the install locally.
Yes, can download and save.. and yes.. we were trying to install over the internet ( worked last time I did it 2 days ago.
when i get back to work on tuesday, i'll try downloading that file and saving it then install locally and see what I get.
thanks for all the help so far.
will report back when i get back to work.
soundguy
   / JAVA problems in IE7 #18
soundguy
Another nice thing about downloading it and saving it is that if it messes up, you don't have to download it again. ;)
good point.. had i done that in the first place I'd already have it..
soundguy
   / JAVA problems in IE7 #20
We do this so much at work that we have a network share with most products like Adobe Acrobat Reader, flash player, java, etc... in it as well as printer drivers, OS cds, and other program CDs. Seems we always need to download something. For instance, if we add a memory stick or replace a HD, some Microsoft products detect a "major hardware change" and require teh installation CD to verify that you aren't making illegal copies.
Anyhow, our software store really does save time.:)
7 30 inch reels (A59228)
7 30 inch reels...
2015 TEXAS PRIDE 30 FLATBED GOOSENECK (A58214)
2015 TEXAS PRIDE...
2018 FREIGHTLINER CASCADIA SLEEPER (A59575)
2018 FREIGHTLINER...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2013 JLG 8K TELEHANDLER (A58214)
2013 JLG 8K...
