JAVA problems in IE7
/ JAVA problems in IE7
I'm saving time and just downloading here on my dsl connection at home and will take it in to work on a flashdrive.. dsl here at home is about 2x faster than work..
soundguy
Still no joy.. firefox, and java download still yeild a jave error when trying to view 'next' pages using java-script..... ARGH!!!
any other ideas what could be causing it?
soundguy
/ JAVA problems in IE7 #23
Does the computer have the latest Windows updates?
it's an xp machine, and windows update is active.. so i assume.. yes.
soundguy
/ JAVA problems in IE7 #25
I,m Certainlly No Puter Whiz , But When I Was Having Problems with Updating Java . I Had to Go to the Control Panel & Remove any Previous Versions of Java . Then Go to tools & Clean the History , cookies & Clear the Cache .
Then Using IE7 I Was Able to install the Latest version With No Problems . But You Might have Allready Went through those Steps . Best of Luck Figuring it out. Bob
/ JAVA problems in IE7 #26
Hey Soundguy, I hate to be the one to say it, but I wouldn't assume that. Most people turn on the auto update, but on a laptop that gets shut down all the time, it never really runs. You might want to go to window update and make sure its got all the latest patches.
Now back to the original issue, this website, can you PM me the URL? Is it publicly accessible? Might help if we can take a look at the under lying code. Just want to see what its trying to do that is causing such a fuss. (e.g what's it really doing for a "next" it should be a simple javascript window call, so is it calling a specific *.js file?) You can PM it to me and I'll take a look.
If its pointing to a specific file type, which is what its telling me when you get that unknown type error for the properties, then you are going to need make some manual changes in the file associates/registry so that it works correctly. (since the re-install of java failed)
Unfortunately it's not a publically accessable website.. at least the part we are having problems with isn't.. it's a site that serves local and state govt /contractors doing work for the govt/state.. part causing the trouble is on the secure side.
I'll try to hit it here with my laptop and see what the jave link looks like.
also.. to bring all up to date.. all previous jave was removed and purged.. firefox was installed even.. then java executable downloaded and installed locally after it wouldn't install online.
both firefox and ie7 are having problem with the link.. which is merely a 'NEXT' page link.. E.. do a search.. and 20 mages of info come up.. the button to push for the nex page of data is a java script..
on this laptop, if you hover over or look at the property of the link it says this:
javascript:ShowPage(2)
soundguy
/ JAVA problems in IE7 #28
OK, it definitely sounds like Java while it may have reinstalled, didn't configure it self correctly. Which is not unusual for some software installers.
So lets try the easy fix, before we go with the more complicated manual registry changes.
If you go in the the control panel look for the icon for JAVA, double click it.
(START > SETTINGS > CONTROL PANEL)
On the General tab, in the "Temporary Internet Files" section click on the "Settings" button.
In the new window that pops up -
Click Delete Files in the "Disk Space" section.
In the next window uncheck the box for Trace and Log files, leaving the Applications and Applets checked.
Click OK.
Click Apply.
(Doing this will delete the special JAVA temp files and force any previously downloaded javascript files and applets to re downloaded. )
Next go to the Advanced tab.
Find the object in the list called "Default Java for Internet Browsers" click the plus to expand it.
If both check boxes for IE and Mozilla are checked, then un-check them and click apply then ok (little popup window saying you will need to restart the browser)
If none of them or one of them is checked then check uncheck the one that is checked and click Apply, then ok.
The idea is to cycle them through till they are all checked again, this will cause the software to reset the registry entries. Hopefully correcting the problem.
Once all done click on and reboot the PC (It is Windows after all)
Let us know the results. If that fails then its the manual registry entry phase, and that's not fun.
HTH,
/ JAVA problems in IE7 #29
Soundguy, have you tried any other sites that use java after the reinstall. You said this is a secure website, maybe try something unsecured to see if java works on them.
Try this test page , you should see a dancing guy if java is working.
How do I test whether Java is working on my computer?
If your still having issues then id say try what Lil_FarmerJim posted above
/ JAVA problems in IE7 #30
Scooby, that tests one piece of the JAVA, the run time engine for applets. What Soundguys describing is the scripting engine, different registry entries.
But still worth testing to see how bad the corruption really is.
Cheers,
I printed out this page and as soon as I get my hands on that pc ( when he comes back into the office), I'll check those settings, and then check that link.
will post back as soon as I have done that.
thanks
soundguy
Altec Digger Derrick Hydraulic Boom (A61572)
Altec Digger...
2027 . . (A67714)
2027 . . (A67714)
CAT D6 SU Blade / Arms (A68134)
CAT D6 SU Blade /...
2015 PETERBILT 389 T/A 6X4 SLEEPER TRUCK TRACTOR (A69167)
2015 PETERBILT 389...
16ft. Terry Bass Boss Flats Fishing Boat w/ 18ft. S/A Boat Trailer (A66738)
16ft. Terry Bass...
T/A CO2 Tanker Trailer (A64194)
T/A CO2 Tanker...
