Loose clothing - dumb
/ Loose clothing - dumb #1
jimmyj
Elite Member
Ontario Canada
Allis Chalmers 616 (Two) and a Kioti CK30 HST with loader and backhoe
The first really warm day was glorious yesterday. I figured I would do some work in the yard with the BH.
Well, it got hot so I put on loose walking shorts. Later, when I was getting off the tractor to walk to the back get onto the hoe (Kioti has 2 seats, one for tractor and one for hoe), the gear shift lever went up in my loose pant leg and snagged as I got off. I was actually pulled off my footing since my upper body momentum was already well into exit mode and I got hung for a moment. Then, I actually was pulled off my footing and fell off the side of the tractor onto the ground with my legs up on the floor of the tractor.
Lesson about loose clothing loud and clear.
Not proud of it but nothing is broke and I'm not hurt so I'm not afraid to admit that I am still learning and I have to be more careful as a new operator. Also, I'm glad I had the parking brake on and the tranny in neutral or maybe somehow I could have run myself over or broke something. Everybody be careful!
/ Loose clothing - dumb #2
Happy to hear you didn't get hurt and thanks for sharing...All it takes is a second.
Don
/ Loose clothing - dumb #3
I can relate jim. I was getting off the tractor from BH position when my loose flannel jacket got caught on the joystick. The BH boom was on the ground at the time and the joystick was moving the boom to MY direction!! There I was - standing there horrified trying to stand taller to releive the pressure on joystick with boom still coming. In my last ditch effort I yanked on the jacket as hard as i could and ripped the jacket and everything came to a stop! As I breathed a sigh of relief, I relized how darned lucky I was and everything could have turned for the worse. From this day forward, the tractor is set at idle where the hydralics will not work before I get off. I don't care how much time it takes to rev down before getting off, but I am not going to go through that again!!! This is the only time I ever had a "unsafe operation" with my tractor and I certainly hope it the last time. (oh yeah, I used the ripped jacket to get a new one. It was getting old and ratty anyways ;))
Glad to hear you not hurt jimmyj!
/ Loose clothing - dumb #4
Glad to hear your ok..
I've done some similiar things, but so far I hae managed to escape injury..
It always happens when one is tired and lets the guard down..
Later,
J
/ Loose clothing - dumb #5
Seems to me its more of a lesson on not wearing shorts than loose clothing.
/ Loose clothing - dumb #6
I was bushogging with a loose sweater-shirt on and as I moved my arm forward the sleeve caught the 3 point lift lever and lifted the full speed running bushhog all the way up before I could stop it. Luckily, it just threw a little dirt on me, but those blades turning full speed just a short way from my head was very unnerving.
/ Loose clothing - dumb #7
These posts are so good, more and more stuff to be mindfull of.
Seems to happen when tired or when rushed.
Pays to take your time.
Thanks for sharing,
Joel
Greenmule, I think if the shorts were not so baggy they would not have snagged on the lever. That's what I meant, point taken though, anything and everything may be a risk.
/ Loose clothing - dumb #9
You will now have to wear your tight fitting Speedo's while tractoring.:)
John
/ Loose clothing - dumb #11
Add a set of chainsawin' chaps and wach out! :D
John
/ Loose clothing - dumb #13
I helped a buddy of mine deliver furniture to a nudist colony before.. One of those "what was I thinking" days. Not at all what I had imagined.
John
/ Loose clothing - dumb #15
John
My dad used to sell Medicare supplement insurance. One of his clients lived in a nudist colony retirement community type place. He said those visits were rather disturbing.
/ Loose clothing - dumb #16
Jim,
Just checking in to see what you had been up to with the new tractor. Glad to hear there were no serious injuries...unless you count pride...but since you posted about this, I guess that has remained in tact as well.
Since you're sharing stories...the dumbest thing I've done so far was grabbing a still slowly rotating Snow blower Auger to confirm that the shear bolt had broken. It hadn't and I got good tug towards the business end of the thing. Dumb! I've actually lost sleep thinking about what could have happened.
About your neighbor.... that's why I love living in the county. It's easier to "love thy neighbor" when there are two hay fields between you.
Later.
JL
You want to talk dumb, I did it two more times both which caused me to fall over again.
I am programmed now because of this and it WON'T happen again.
/ Loose clothing - dumb #18
I see the makings of a TBN beef cake calendar here. :D
/ Loose clothing - dumb #19
I had to read my wife this thread.... in hopes to get her to stop laughing / nagging me. I did the same exact thing on the 4wd lever on my Kubota. It has happened before where I caught my shorts and kinda tripped up getting off, but this time I got hurt. Momentum carried me (or the top half of me) off the tractor while my legs twisted and stayed on the platform. I wrenched my bad bad enough to go to the doctor. Hit the ground with my head, arms and shoulder. Nothing torn or broken, but having back surgery 3 years ago, anything this "minor" is cause for concern.
Think twice before getting off wearing loose clothing. I now hold my shorts with one hand and the FEL bar in the other.
Paul
Pashworth, that is exactly how I fell. Sorry you got hurt though.
I feel silly now but EVERY time I get on or off I hold my shorts tight with one hand.
WACKER NEUSON  LTN8 LIGHT PLANT (A68842)
WACKER NEUSON...
PORTA POTTY (A68842)
2014 FORD F-150 (A67714)
2014 FORD F-150...
5'x8' Metal Plate (A64912)
5'x8' Metal Plate...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
(2) Goodyear 16.9-24 Tires (A64911)
(2) Goodyear...
