Oil & Fuel Oil pressure for a 1700
/ Oil pressure for a 1700
Thanks for the advice, there was no throttle return spring, I added one and it works great.
I fixed the temp problem, now it maxed out at 180-190 working and about 160 just driving around. It currently is straight water.
/ Oil pressure for a 1700 #13
Straight water=rust=bad for the engine.
/ Oil pressure for a 1700 #14
That is about right. That is real close to what I get on my 1700 except the temp. I added a water pump and mine runs about 140 to 150 in the summer.
What size is the bushing that threads into the block so you can hook up the verral fitting to
/ Oil pressure for a 1700 #15
I don't really remember the size of the adapter. I had to buy a metric adapter kit for about $7 that had the correct size in it. They were hanging on the shelf right next to the gauge kit. I figure it was cheaper than running all over town trying to find it. I will try to measure it this weekend.
You might try to search the forum for "gauge". Someone may have posted that info before.
/ Oil pressure for a 1700 #17
Just a note: My 1700B was manufactured with a water pump.
And when I push my throttle off, it engages an Elect kill switch.
/ Oil pressure for a 1700 #18
What electric does it kill? The tractor doesn't require any electric to run.
2013 Mercedes Benz E350 AWD Sedan (A59231)
2013 Mercedes Benz...
2018 HINO SA (A58214)
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2019 PJ TRAILER 32FT GOOSENECK (A58214)
2019 PJ TRAILER...
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
