Oil & Fuel Oil pressure for a 1700
/ Oil pressure for a 1700 #1
mikereid
Jackson, GA
Yanmar YM1700
I put in some manual guages and I am trying to figure out what the values should be running.
What is the oil pressure supposed to run on a 1700 that is at running temp?
I am getting 45@ 1000
40@ 1500
50@ 2200
Also, how hot should the tractor be running?
I am running between 210 and 220.
Thanks for the help,
Mike
/ Oil pressure for a 1700 #2
Mine is running around 180-200 under load. Oil pressure at full temp is right around 50psi plus or minus a couple of pounds depending on engine speed.
/ Oil pressure for a 1700 #3
That is about right. That is real close to what I get on my 1700 except the temp. I added a water pump and mine runs about 140 to 150 in the summer.
/ Oil pressure for a 1700 #4
I have a water pump in the mail!:D
/ Oil pressure for a 1700 #5
The water temp does sound high .I believe the temp sending switch should come on at 220 Degrees. If you do not have a water pump which I recommend getting for this area the coolant ratio should be 75 water 25 antifreeze to get the proper water flow.
I will check the ratio. Have any of you ever tried water wetter? I used it on high compression cars and it dropped the temp about 20 deg.
what is the radiator cap lbs need to be? The one that is on it says 7.
Thanks for the input, this site is great.
/ Oil pressure for a 1700 #8
Yes I have heard that it does work.Have you checked the radiater it may be due for a recore or new one depending on the cost.But since you just bought it first I still would go the water pump kit.And come to think of it you may can even go lower on the mix ratio prob. down to 15% until you change it over.Maybe someone else will chime in on that.Since the oil pressure seems to be okay no mention of oil useage or smoke and you get it cooled down you should be in good shape.Also on oil pressure there is a lever to the left that is the decompression lever.what it does is holds up the valves for cold starts.I use it to let the oil pressure to come up before I let it start on average 5-8 sec.There is a good article on Hoye web site for your tractor under tech info yanmar over heating if you would like to read up on it.
I will flush the system tommorow. Also the water did look a little too green. It is not going to freeze any more this year, I think I my put straight water and water wetter in it to see If that will do me for a short while to get the garden tilled.
By the way, How do you turn off your engine, I have been having to use the decompression lever. I did notice after looking at some of the closeup pics on the site that there is suppose to be a return spring on the throttle. That could be the reason I can not throttle it off.
Thanks guys for the input.
/ Oil pressure for a 1700 #10
Your throttle linkage is out of adjustment most likely.It's not pushing the pump arm far enough forward to shut the fuel off would be a good guess off the top of my head.
Thanks for the advice, there was no throttle return spring, I added one and it works great.
I fixed the temp problem, now it maxed out at 180-190 working and about 160 just driving around. It currently is straight water.
/ Oil pressure for a 1700 #13
Straight water=rust=bad for the engine.
/ Oil pressure for a 1700 #14
What size is the bushing that threads into the block so you can hook up the verral fitting to
/ Oil pressure for a 1700 #15
I don't really remember the size of the adapter. I had to buy a metric adapter kit for about $7 that had the correct size in it. They were hanging on the shelf right next to the gauge kit. I figure it was cheaper than running all over town trying to find it. I will try to measure it this weekend.
You might try to search the forum for "gauge". Someone may have posted that info before.
/ Oil pressure for a 1700 #17
Just a note: My 1700B was manufactured with a water pump.
And when I push my throttle off, it engages an Elect kill switch.
/ Oil pressure for a 1700 #18
What electric does it kill? The tractor doesn't require any electric to run.
2013 Ford Explorer SUV (A59231)
2013 Ford Explorer...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
UNUSED IRANCH 15" TOOTHBED MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 15"...
2002 Blue Bird F131612 Bus (A59230)
2002 Blue Bird...
