Suggestions for new compact tractor
/ Suggestions for new compact tractor #1
cdcj
SE Arkansas
I am looking for suggestions for a new 30-35 hp tractor to clear up around 2 acres at my house plus 120 acres that my Dad and I picked up to deer hunt. I have looked at the Cub 3200, Kioti DK 35 hp, Mahindra 16 series, and New Holland. I can get the Cub about 2 miles from me. John Deere, Massey, and Kioti about 30 minutes away. The New Holland, Kubota, and Mahindra about 1 hr away. All dealerships have service.
I am going to use heavy 5 ft bush hog, disk, and box blade to clear up trees and briars.
/ Suggestions for new compact tractor #2
cdcj,
Welcome to the club. Well for starters any of the tractors that you listed will do the task that you want to do. The New Holland and the John Deere are great proven tractors. I'm parcel to the Kubota's though, as I truly believe they set the standard for the rest to follow,now saying this I did not intend to start a debate with which tractor is best.One thing you need to consider though, are you planning later on to add a FEL or backhoe to tractor? because If that's in your plans I would stay with the big three.
DevilDog
/ Suggestions for new compact tractor #3
cdcj,
DevilDog
What's the reasoning behind this? I see no foundation for such thinking.
/ Suggestions for new compact tractor #4
Well they are more expensive so they must be better... :rolleyes:
The Kioti will give you more weight, higher capacities, longer warranty, more standard options, and the same orange paint for thousands less.
Of course I guess I am partial too! :D
The big question is Do you want a cab? Not many make a cabbed version in that size.
/ Suggestions for new compact tractor #5
It could be that he is thinking that there is a greater possibility that the loader / backhoe will still be available a few years down the road from the original manufacturer. I'm sure the statement has nothing to do with the capabilities of other tractors / loaders / backhoes.
/ Suggestions for new compact tractor #6
What do you need to do on the 120 acres. If just mowing you're going to spend a long time in the seat.
/ Suggestions for new compact tractor #7
If you plan to use your tractor on that 120 acre parcel, you need to think through your requirements carefully. If you're cutting/maintaining trails and/or establishing food plots on that 120 acres, then 30-35 hp might be sufficient. If you're planning to do a lot of field mowing and/or tree removal, then a larger tractor may be better.
Remember to figure out which implements you're going to need before you commit to a particular tractor.
/ Suggestions for new compact tractor #8
This would only be a valid point if one were going to wait 10 to 15 years before buying the loader/backhoe.
/ Suggestions for new compact tractor #9
There are more options with the big three (or five), more attachment mfg making implements designed for the easy hookup.
Of course given the steel and a Bronson rock (Urban Dictionary: Bronson rock) you can always build your own.
Not planning on doing a lot of tree removal because we do not own the land. Family friends that can not keep it up but will let us do what we need to do with exception of taking down trees. They may allow us to remove some smaller gum trees. There is about 20 acres that will need to be cut once a year. Several spots where 1/2 to 5 acre food plots could be established.
/ Suggestions for new compact tractor #12
if you're going into the woods, check the width of the back tires - not all brands are the same. For example, my current mahindra 3510 is 6-8" wider to the outside of the tires than my previous Century 2535 (same as Branson 3510).
also compare PTO HP, since that's what drives implements like a brush hog mower. (figure 5 PTO HP per foot of rotary mower, so 28-32 PTO HP can handle a 6' mower without stress)
also consider weight and frame size.
the Kioti CK35 and DK35 have similar HP & PTO ratings, but the DK is about 1000 pound heavier and longer, taller, wider, to boot. (Same song with other brands as well)
If you want traction and pulling power, get the larger frame. if you need to be able to get in tight spaces, go with the smaller one.
It's hard to find a BAD new tractor at tis point in time. some machines will require more initial prep work (upgrading hoses, exchanging fluids, etc...) and more preventive maintenance, etc... but overall, it's going to come down to what's important to you.
Low price up front with more sweat equity over time?
high price up front with high cost OEM parts?
or less common name but good quality, reasonable prices on parts, but less dealer support network. (same dealer support, they're just farther apart on the ground)
/ Suggestions for new compact tractor #13
I think you can get a cab with the Massey 1533-1540 and mabey the new 1600 series.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2011 MAGNUM PRODUCTS LIGHT PLANT/TANK TRAILER (A58216)
2011 MAGNUM...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
