Looking for a safe hay baling tractor on mild slopes
   / Looking for a safe hay baling tractor on mild slopes #1
koerbdog77
I have a John Deere 790 and I know it is to small for hay baling attachments. However I find it to be real tippy when brushogging. I want to buy a tractor largest enough to handle hay baling attachments and was wondering what I should buy. I am a newcomer to tractor driving and was wanting the safest model I can find.
   / Looking for a safe hay baling tractor on mild slopes #2
What type of bales--small square, large square, round? What's the bale weight? Can't give a good answer unless you provide more info.
   / Looking for a safe hay baling tractor on mild slopes #3
Wouldn't you want to buy a tractor that your could adjust the wheels OUT WIDE?? Don't you think it would be worth your while to buy a true farm tractor? Off the top of my head I can adjust my tractor wheels out to about eighty inches width. All I do is losen four bolts per wheel, get on the tractor, put the brake on the side I am not adjusting and put it in gear, either forward or backward depending on what I am doing, widening or narrowing the width, then let the clutch go and it will spin out or in.
Question again, why would you buy a farm tractor that can't be used for true farm use??
   / Looking for a safe hay baling tractor on mild slopes #4
What about a tractor like the county mowing crews use? Low, wide and made for hillsides. I've seen new holland ones, they look very stable.
   / Looking for a safe hay baling tractor on mild slopes #5
My JD 5420 is absolutely perfect for making hay on the hillsides that I am working. I have a JD 327 square baler with #40 kicker and pull 8x16 hay wagons. I have added some rear ballast (loaded tires and 200 lb/side wheel weights) for loader work and a 200 lb starter weight on the front. This gets the unit weight up to about 8300 lbs with a full tank of fuel which is plenty for controlling the weight of the baler, wagon and hay.
Note that I do take the loader off when making hay. I am yet to run into a pucker up moment making hay with this set-up. There is one field that I have to make sure I start out with an empty wagon for fear of tipping a full wagon load over (top heavy), but the tractor is completely stable.
All that having been said, you could get away with a 52XX or 53XX series tractor as long as they had enough PTO power for your equipment. There are wider and lower units available and you will have to assess that need based on your conditions. Give us a hint where you are at and we may be able to help you some more.
I hope this is helpful. If you have any further questions, just ask.
I live in WV near charleston. I would like to bale round bales, Probably around 750 pounds. The wide and low tractors referred to above, would those be massey ferguson? I bought the JD 790 several years ago and just bought a farm last year.
   / Looking for a safe hay baling tractor on mild slopes #7
A 5000 series JD is what you need to do what you want to. I am sure a Massey would work for you too, if your looking for something older, something like a 275 would be perfect.
   / Looking for a safe hay baling tractor on mild slopes #8
A round baler like you want would need about 45 pto hp, something like the JD 448 baler or similar. There are lotsa tractors in this hp range. For example, my haying tractor is a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, partial constant mesh tranny, power steering).
I traded that little 21 hp (engine ) 2005 Kubota B7510HST in the photo for the 5525 last year.
My old 1964 MF 135 diesel is a field tractor that's been modified for orchard work by using short front axle spindles and replacing the 28" rear wheel rims with 16" dia rims.
The 135 rear axle is 20" above grade and the tires are 83" wide (measured to the outside tire wall). The 5525 has standard 28" dia rims so the rear axle is 25" above grade with tire width of 71" with the rear wheels adjusted for max track width.
If stability is a major concern of yours, you could lower your tractor's CG similar to the way it was done with my MF-135. Or you might be able to use dual rear wheels to widen the track and take the tippiness out of your ride.
   / Looking for a safe hay baling tractor on mild slopes #9
Lowering a tractor like that isn't a good idea for a baling tractor that has to stradle the windrow.
That is a neat looking 135 :cool:
   / Looking for a safe hay baling tractor on mild slopes #10
Recommending a specific brand for the parameters listed makes no sense. So long as the buyer stays away from special purpose narrow, orchard, and vinyard models, just about any wheel tractor's tires can be set wide enough to work steep slopes safely. Proper ballasting and 4WD are also considerations, both widely available.
   / Looking for a safe hay baling tractor on mild slopes #11
Sure it does,the OP asked about a certain brand so he mst have had something in mind.
   / Looking for a safe hay baling tractor on mild slopes #12
oops LOL
   / Looking for a safe hay baling tractor on mild slopes #13
Howdy neighbor and welcome to TBN.
Howdy neighbor, you wouldn't happen to live off the Amma exit?
Would the low profile tractors be a speciality type tractor that I should avoid or are they a safer type tractor since they have a lower center of gravity? I am looking at the 500 series LP MF.
   / Looking for a safe hay baling tractor on mild slopes #16
That seireis of tractor should work good.
I doubt you need a LP but that is for you to decide.
   / Looking for a safe hay baling tractor on mild slopes #17
I used a 596 MF when I started baling last year. Switched to a MF 5455 in the middle of hay season. One of the 500 series would work for you and they are solid workhorse tractors. If the slopes are mild I would not worry about the LP series myself, but as long as they did not sit so low to the ground as to interfear with the windrows they would not have any disadvantages either. I would set the wheels out for stability and load the rear tires though on the regular model. A tractor with a heavy basic weight is always a good thing in a baling tractor with round balers. Being pushed around a hayfeild is not fun at all. I run the 105 hp 5455 in front of a MF 2746A (4x6) round baler as a small custom operator. You would not need that much tractor with 4x4 or 4x5 bales. A 573 or a 583 would probably do nicely for you. I really do prefer having front wheel assist(especially with a FEL), but it is not really necessary in most conditions.
   / Looking for a safe hay baling tractor on mild slopes #19
You could use the following products with your JD790...;)
AGRIQUIP.com :: Star
   / Looking for a safe hay baling tractor on mild slopes #20
Back in the early 1990's I lived in Hurricane WV. I worked at all of the AEP power plants up and down the Kanawha, the Ohio and the New rivers.
Depending on where your at down there you can have gentle slopes to sheer vertical. The key words, regardless of the tractor selected, are width and balast. Make sure that your tractor has enough weight to hold back the weight of the baler and a full bale with margin. Four wheel drive gives extra margin of safety, especially if the ground gets wet from a freak rain shower. I wouldn't hay my ground without having either four wheel drive or a much bigger tractor (with differential lock).
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58214)
2011 MULTIQUIP...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
5ft Rotary Brush Cutter Tractor Attachment (A59228)
5ft Rotary Brush...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
2426 (A60432)
2426 (A60432)
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
