Looking for a safe hay baling tractor on mild slopes
/ Looking for a safe hay baling tractor on mild slopes #11
Recommending a specific brand for the parameters listed makes no sense.
Sure it does,the OP asked about a certain brand so he mst have had something in mind.
/ Looking for a safe hay baling tractor on mild slopes #13
I live in WV near charleston. I would like to bale round bales, Probably around 750 pounds. The wide and low tractors referred to above, would those be massey ferguson? I bought the JD 790 several years ago and just bought a farm last year.
Howdy neighbor and welcome to TBN.
Howdy neighbor, you wouldn't happen to live off the Amma exit?
Would the low profile tractors be a speciality type tractor that I should avoid or are they a safer type tractor since they have a lower center of gravity? I am looking at the 500 series LP MF.
/ Looking for a safe hay baling tractor on mild slopes #16
That seireis of tractor should work good.
I doubt you need a LP but that is for you to decide.
/ Looking for a safe hay baling tractor on mild slopes #17
I used a 596 MF when I started baling last year. Switched to a MF 5455 in the middle of hay season. One of the 500 series would work for you and they are solid workhorse tractors. If the slopes are mild I would not worry about the LP series myself, but as long as they did not sit so low to the ground as to interfear with the windrows they would not have any disadvantages either. I would set the wheels out for stability and load the rear tires though on the regular model. A tractor with a heavy basic weight is always a good thing in a baling tractor with round balers. Being pushed around a hayfeild is not fun at all. I run the 105 hp 5455 in front of a MF 2746A (4x6) round baler as a small custom operator. You would not need that much tractor with 4x4 or 4x5 bales. A 573 or a 583 would probably do nicely for you. I really do prefer having front wheel assist(especially with a FEL), but it is not really necessary in most conditions.
/ Looking for a safe hay baling tractor on mild slopes #19
I have a John Deere 790 and I know it is to small for hay baling attachments. However I find it to be real tippy when brushogging. I want to buy a tractor largest enough to handle hay baling attachments and was wondering what I should buy. I am a newcomer to tractor driving and was wanting the safest model I can find.
You could use the following products with your JD790...;)
AGRIQUIP.com :: Star
/ Looking for a safe hay baling tractor on mild slopes #20
Back in the early 1990's I lived in Hurricane WV. I worked at all of the AEP power plants up and down the Kanawha, the Ohio and the New rivers.
Depending on where your at down there you can have gentle slopes to sheer vertical. The key words, regardless of the tractor selected, are width and balast. Make sure that your tractor has enough weight to hold back the weight of the baler and a full bale with margin. Four wheel drive gives extra margin of safety, especially if the ground gets wet from a freak rain shower. I wouldn't hay my ground without having either four wheel drive or a much bigger tractor (with differential lock).
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
TANK MANIFOLD (A58214)
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
FORKLIFT (A56857)
FORKLIFT (A56857)
(12) SKLP SK-LJB-12 Polyethylene Roadbed Protection Pads (A60463)
(12) SKLP...
